Question about Sony PlayStation 2 (PS2) Console
Disc Tray The disc tray won't open, blue light blinks and noise from inside like it might work but it won't open
    Problem Solver:
  • 20 Answers
The rubber band inside your PS2 might be broken, the rubber band supports the disc tray and it ejects and inserts the tray.
Sometimes if play too much long, some of the PS2 parts will be damaged by excessive heat, so my advice is that your minimum gameplay time must be 3-4 hours only.
Please den't even try forcing the tray to open, it will be more damaged.
Try resting your PS2 for about 1-2 days, after that try to open the tray, if the problem still persist bring to a PS2 fixer near you.
Posted on Aug 03, 2008
DVD/CD disc opener won't workGetting
Usually the tray has to be opened and inspected and if lucky it can be realigned--if not parts may be hard to find as they usually do not sell individual parts for the mechanism.
Nov 05, 2012 | Televison & Video
My dell 1645 disc drive won't open , I burnt a
There should ba a tiny hole on the front of the tray cover on the drive.
Switch off, get a paper clip or something about the same thickness and insert it carefully in to the hole, push it in until the tray opens.
Jan 08, 2012 | Dell Computers & Internet
MY id58 GATEWAY DVD PLAYER, i cant insert a disc because blocked by the mechanism eventhough there is no disc inside.
There is a small hole on the front of the drive. Use a paperclip or a safety pin in the hole to push open the disc try enough to pull it open the rest of the way with your hand. Insert the disc, press the button on the drive to close the bay. If the tray doesn't close gently push the tray back in. If no lights blink on the front of the drive, the drive may be unplugged or has gone bad.
Jul 06, 2011 | Computers & Internet
The disc tray on my iView 4000KR won't open. It has a disc inside that plays fine, but won't eject. This has never happened in the 18 months I've had the player.
Under each disk tray is a very small hole; this hole is for use when you experience the problem like yours.
Get a paper/money clip and straighten the wire; push the wire into this hole and your disk will open.
Regards
HCF
Jun 22, 2011 | Computers & Internet
Disc changer won't open, won't play DVDs. RCA RTD
Check the belt inside underneed the tray if this is still in place.
if not put belt back on
Feb 15, 2010 | Bose Lifestyle 12 System
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
Blinking green light on 1 tray
You could have a faulty drive.
To open the tray, you need a paper clip, straighten it and place it in the small hole below the disc tray, push it in and the tray wull pop out slightly, remove paper clip and pull the tray fully out with your fingers.
Then try to close and open the tray with the push button, if it does not work you need to replace this drive with a new one.
Sep 24, 2008 | Acard Technology (CD1TO7T) CD-RW Burner
Disc tray
My console does the same thing just take the faceplate off and when you press the open button grab the disc tray and gently assist your console in pushing out the tray. Taking the faceplate off does not terminate your warranty.
Jan 12, 2008 | Microsoft Xbox 360 Console
Disc tray stuck closed
Is it making the noise like it will open then getting stuck? If so, this can be tricky! It happens with me sometimes. Press the open button and as it goes to try and open push the disc tray in slightly and up and it should pop open, it does with me anyway.
Oct 22, 2007 | Microsoft Xbox 360 Console
Xbox does not read discs.
Getting to the dashboard screen is a good thing but still cannot rule out a bad circuit board or power supply. All the symptoms point to a bad DVD drive but the opening/closing by itself do indicate a problem with the microprocessor. Can you turn the power on and off with the small button?? If not, would definitely suspect bad board.
Aug 16, 2006 | Microsoft Xbox Console
Sony PlayStation 2 (PS2) Console Logo
282 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
