No. Your defrost cycle is not working. Depending on the age of your fridge, you could have a defrost timer or an integrated defrost timer on the control board. You also have an electric defrost heat that wraps your freezer coil that defrosts your coil. You didn't leave any info on your unit so I cant get more specific, but your issue is your defrost cycle and not your compressor
SOURCE: defrost thermostat connector
Where is the defrost heater? If it is below the problem area, I don't think it is a defrost problem. This sounds like low freon. The symptoms of this are heavy frost on only part of the coils. Try deforsting with a hair dryer and putting it back together. Wait about 3 hours and look again. If there is frost only on part of the coils that is bad. The most this unit could defrost is every 4 hours, most are on 8 or 12 hour cycles. On most units the defrost timer shuts off the compressor and gives current to the defrost heater/s through the defrost thermostat. This thermostat is closed below 15 degrees and opens at a much higher temp after sensing the heat. This shuts off the heat usually before the timer and lets the water drip down where it should go. Then the timer turns the compressor back on and removes current from the defrost system. A common defrost problem is if the doors are left open for a LONG time or not shut all the way. Sometimes it causes so much ice that it can't melt with just one defrost cycle. This problem builds as if air flow is restricted it causes even more frost and gets worse. If this ever happens , just find the defrost timer and turn it very slowly click by click just until the compressor stops. Let it defrost , then do it again in about 2 hours. If it is a low freon problem there may still be a partial warrenty left sometimes the sealed system is guarenteed ror 5 - 10 years. Sometimes if it is not covered it is not worth fixing.
SOURCE: Ge Profile Top freezer-not cooling/not freezing
Evaporator fan motor inside the freezer is working? Any frost on the freezer back wall?
This is the fan inside the freezer section, it will circulate the cold
air around in the freezer and blow the cold air from the freezer into
the fresh food section, it also sucks the warm air from the fresh food
section back into the freezer to be re-cooled.
Hot condensor coils ( under the refrigerator ) been cleaned recently?
**GSS25LGMA**
That is part of a full model#.
SOURCE: compressor runs continuously, and center bar (heat dissipator) is extremely hot to touch.
Molly, The hot bar is a normal part of the sealed system (compressor) operation. The relay they told you about is on the back of the compressor and I would not recommend you changing that. The refrigerator is a balanced system, the freezer air removes the heat from the refrigerator side. If the compressor runs all the time, look for food close to the edge and not letting the doors close completely. Move items back. Don't over pack the freezer, the air must circulate. The refrigerator of today runs longer and uses less power that the old refrigerator. If you are still having issues with this model call a authorized Kitchen repair person in you area and ask how much they charge to come to your house and give an estimate.
SOURCE: GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
SOURCE: the ref technician said that the compressor of
most only need the model and serial number of the unit.ref. freezer
