Question about Sony STR-DA777ES 6.1 Channels Receiver
Str-da777es my daughter keep pressing the on and off button constantly now the receiver does not switch on and when i press the on and off button it seems its conecting but it want.There is a click sound i hear when every time i press the on&off button ,can you pls help me to fix it thanks.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
I know I'm 18 months late answering your question, but unfortunately I have the same problem. My son kept shutting my on and off same as your daughter. It blew the amp board that obviously powers the amps. Sad news is Sony stopped making the board, so there is no fix. Really bites, I loved that receiver!
Posted on Mar 15, 2010
Protector
Look for any bulging on metal capacitors. As they age they can fail, but won't show it until power is stopped for a time. Then when you try to power up the system the fault shows itself Replace all that look that way
Jan 14, 2014 | Sony Str Da777es 600 Watt Receiver
Speaker switch .will only activate speakers if I kep the switch pressed all the time
These unit had a habit of getting broken solder connections between the board that the speaker switch and power button are on and the display board. Would have to repair these bad connections for unit to work right. Pretty easy soldering job if you have any experience.
Mar 27, 2013 | Sony STR-DE945 Receiver
Having problems with my SONY str-db798 amp. When i turn it on (without any speakers or even with speakers) it flashes "PROTECT" and shuts down. Any suggestions how to deal with it without getting...
Press and hold down the power button on the front panel until you hear a secondary "click" from inside the chassis. That takes about 15 seconds.
Then read my tutorial on how to keep your receiver out of protect mode.
Sep 03, 2011 | Sony STR-DB798 Receiver
My STR-DE835 receiver will not stay powered on
Most likely bad output transistors and a couple of resistors. mp1620 and mn2488 are the part #s for the transistors. If you take it to a repair shop you are looking at spending $100-$130
Nov 16, 2009 | Sony STR-DE835 Receiver
I have a sony str-db940, since it came back from being repaired, it reports 'not in use' when the 'sur' button is pressed and won't decode surround sound. Any ideas?
Check if you're using the digital cables like optical cable to get the audio from the receiver. If yes, please select the Input mode to AUTO by pressing the mode button repeatedly. If you're using a analog cables, please try to change the sound field and check. Press the A.F.D button repeatedly to change the sound field and try. You can also try connecting a different audio source like Cable box, dvd player and check the issue.
If the issue persists, please reset the receiver. To reset the Receiver, turn OFF the unit and press n hold the MODE + button and Power button till S.F Initialize appears. If the issue still persists, you may be having 90 days warranty after the date of repair or original warranty which ever is longer. Contact sony to resolve the issue.
Sep 26, 2009 | Sony STR-DB940 Receiver
Sony str db870 master reset
If the power of the Receiver is ON, press Power to turn OFF the power. Then, hold down the MODE + button and press the Power button together.
S.F Intialize appears in the display and all sound fields are reset at once.
Sep 22, 2009 | Sony STR-DB870 Receiver
Audio out from Receiver to TV
Check to see if it says LINE OUT - if it does try that. Let me know if it works.
Mar 28, 2009 | Sony STR-DA777ES 6.1 Channels Receiver
I have a Sony STR-DE635. It has a switch on the front for speakers A, B, and A+B. Normal. When I am on speaker A only, it works fine. B does not work. A+B works, but only through the A speakers. Now,...
Check for bad solder connections on the speaker switch or where the speaker switch board connects to another board. Not an uncommon problem with some Sony receivers.
Feb 25, 2009 | Sony STR-DE845 Receiver
Have unlock problem on str-da1200es receiver
Sounds simple, but could the input mode button been pressed accidentally? Try setting this to auto and see if the unlock message switches off. This happened to me! :-)
Jul 26, 2008 | Sony Audio Players & Recorders
Receiver misinterpreting IR signals
There can be a few causes of this. Since it happens with a number of remotes, we can state that the problem is inside the receiver. In the front of the receiver (inside) you should see a small silver box. Inside that is the InfraRed receiver. This is a 3 pin device. Check to be sure that the pins have good solder joints. A bad joint can cause problems. Also, after the receiver comes what is called a digital switch. This is similar to a transistor except that it makes the transitions more steep, like a step rather than a ramp. If this part is bad you can get these results. The digital switch will be marked c124 (perhaps or somehting close).
Check these out and keep us posted.
Dan
Apr 09, 2008 | Sony STR-DA3ES Receiver
Sony STR-DA777ES 6.1 Channels Receiver Logo
293 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
