Computers & Internet Logo
Posted on Feb 28, 2011
I do job on hcl black and white monitor its functional keys f1 to f6 has been unlocked plz advice me how can it be unlockes
Anonymous
Level 1:
New Friend:
  • Contributor 42 Answers
  • Posted on Mar 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
42
Questions
0
Helped
4362
Points
90
Peculiar ! no chances of blocking functional keys F1 to F6 or upto F12. Clean the functional keys. You may find solution, but depends on key board manufacture. Or otherwise, better to change key board, try, choice is yours.
Code f1 f3 f6
virtual machine - VNC send Ctrl+Alt+F1-F6 to server - Unix ...
unix.stackexchange.com/.../vnc-send-ctrlaltf1-f6-to-serv...
Stack ExchangeMar 15, 2012 - Hence I can switch to the TTY's if my CTRL + ALT + F1 - F6 ... As I understand it, you want to send CTRL-ALT-F3 to the remote .... What numeric keycodes do I need to send for the magic sysrq functionality in a VNC session?
error code f1 dishwasher model gldt696tss 00 KVM Switches
www.fixya.com > ... > error code f1 dishwasher model gldt696tss 00
KVM Switches error code f1 dishwasher model gldt696tss 00 questions and ... 6F 23 20 F1 01 = F2 46 B1 59 04 61 77 71 Telewest 00 = 75 4A 66 04 CF 7F 55 F3 ... ...96 F6 1F C4 01 = 6D EA BE 97 6A AA DA 71 NTL 54 01] 07/10/09 00 = F0 ...
kleenmaid f6 code KVM Switches Questions & Answers - Fixya
www.fixya.com > Forum > Tags > kleenmaid f6 code
KVM Switches kleenmaid f6 code questions and answers. ... 01 = C6 64 1D EF 47 5A 0E EF tellywest 00= B7 DE 73 DE 2F A4 F3 BO 01= FA 4B 82 4C ... ...in bradford area plz 5a 01 83 5D 12 B8 96 F6 1F C4 6D EA 8E 97 6A AA DA 71 Hope ..
How do I fix problem with hp pavilion dv7 that the fan runs but screen remains black and the keyboard does not function
hello Anonymouse
It is possible that the problem in the slide card that beats screen located on the main board and the faults which also appear on-screen plasma appearance of a white image on the screen or the colors are without any data. Easy to verify the integrity of the slide card that beats the screen by pressing of Touch Pad or the left part of Keyboard to the East, including notes. When connecting to an external monitor with no emergence of data
Among these symptoms we see that it is clear that the device temperature was high because of heat produced following larger processor and thus the slide master ICH
Card and slide the screen. However, the slide of the type Intel does not notice the high levels of heat and when exposed to heat the welding related Qdanvsal on the main board of the parent on the board
1helpful
I managed to lock my FN key and i dunno how to unlock it. Please help
Function Keys can be unlocked by using combination of Function (FN) key and any other key. Generally they are the F keys right on the top from F1 to F12.
Most often the following combinations work:
1) Fn + F6
2) Fn + Num Lock
3) Holding Fn for a while
4) Fn + F8
5) Ctrl + Fn
6) Shift + Fn
Please, all most at all times the function keys from F1 to F12 are marked and indicated about what they do. The marking is pointed by a small icon just under the name of the Function key.
How to update older ti-84 plus
The function keys originally have twp functions: One function accessed by pressing a function key directly, the other by first pressing the 2nd key then the function key.
With the newer operating systems, there is a third function associated with the function keys F1.F2,F3 and F4, but not F5 nor F6. This third function is revealed after you press the ALPHA key.
How to remove white and black leakage screen
Your lcd screen has gone bad and needs to be replaced. To isolate that it's the screen or the video card borrow a monitor from a relative, neighbor, friend or co-worker and plug it into the laptop. If the borrowed screen displays fine without any problems then your original screen is bad. If the borrowed screen shows the white area with black leakage ink as your old monitor then the video card in the computer is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
Emachines netbook unlock key pad
Key Pad or Touchpad? Is it that the mouse pointer is frozen and does not work? If so, look at the middle of the touchpad at the top of it and there might be a button there that lets you toggle the touchpad between locked and unlocked.
Sometimes there might be a set of keystrokes you will have to hit to lock or unlock the keypad. Most times you will have to Press and Hold the Alt, FN or Ctrl key then hit the key (most times one of the F1 thru F12 keys) that controls the keypad. The key that controls the keypad will have the icon of a finger inside or pointing at a square that represents the keypad. On one laptop recently that I worked on it was toggled by Pressing and Holding the ALT key then hit the F6 key. F6 had a finger pointing at a square area representing the touchpad.
1helpful
I do not know what the F keys are for, from F1 to F12. Where can I find out please? i DO NOT KNOW WHAT THESE FUNCTION KEYS DO.
The Function keys serve various functions for various programs and with laptops, in combination with the Fn key, the function keys have additional functionality such as increasing or decreasing illumination of the screen, mute on/off, touchpad lock/unlock, switch from external to internal monitor and so on. These special functions are labeled onto the keys themselves.
Here's a short list of what function keys do in various programs:
F1=Help
F2=Rename Desktop Icon
F3=Find
F4=Address Bar Autocomplete
F5=Refresh(on a webpage)
F6=Move cursor in structure (Address-Tool-Web)
F7=Caret Browsing
F8=Enter Safe Mode (while booting)
F9=Update selected text (MS Word)
F10=Menu Bar (MS Word)
F11=Full Screen
F12=Developer Tools
For a more detailed list of functions, take a look at this website http://www.computerhope.com/issues/ch000306.htm
3helpful
My keyboard and mouse ar locked
COUCL BE CAUSE BY THE function key(fn) key and lock key (mostly f6 just find for the lock icon) press this key combination again to unlock fn+f6 to unlock you keyborrd here is a small digram to help you
please rate this solution........
21helpful
5answers
Grand Canyon Tech
Grand Canyon Tech
