Question about RCA RP5010 Digital Voice Recorder
Erase Files dropped from windows real player
I downloaded some music files from my computer using Real Player on Window and it shows them when the DVM 5120 is connected to the computer, but when I unplug the DVM 5120 I cannot find the files.However I have no more space to record. How can I can erase these files i dropped into DVM 5120 from Windows Real Player.
I used Windows Media Player to erase the music data that I dropped using Real Player on DVM 5120.
Posted on Aug 06, 2008
My computer does not recognize ny recorder as an external device
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Jul 03, 2009 | Olympus VN-4100PC Digital Voice Recorder
Olympus ws-110 no playback when connected to pc
ahh...that sounds like a player issue..open your settings on WMP and look to see that it's not on sample mode
Mar 25, 2008 | Audio Players & Recorders
Digital wave player wont pick up recorder when i plug it in
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
12. Click Next
May 06, 2009 | Olympus VN-4100PC Digital Voice Recorder
12. Click Next
Apr 02, 2009 | Olympus VN-4100PC Digital Voice Recorder
I cant transfer files from recorder to my pc
12. Click Next
Mar 12, 2009 | Olympus VN-4100PC Digital Voice Recorder
Cant open or view folders on computer
12. Click Next
Mar 01, 2009 | Olympus VN-120 Digital Voice Recorder
File transfer VN-480PC doesn't work on notebook (Vista)
12. Click Next
Feb 19, 2009 | Olympus VN-480 PC Digital Voice Recorder
I cant download any files
12. Click Next
Jan 24, 2009 | Olympus VN-4100PC Digital Voice Recorder
Update on recommended fix.
HI,
Try changing it to 128kbps and let me know.
Mar 29, 2008 | Audio Players & Recorders
Files on the computer in high speed, while normal on the Recorder
you can format the device, maybe if you delete files on the device from the computer , you cause inconsistence between them, i suggest to erase files using the buttons on the device. about the high speed check the codecs in your computer,
I can’t play a file that Windows Media Player supports. What should I do?Most likely, a required codec isn't installed on your computer. Typically, Windows Media Player automatically downloads any required codecs from the Internet and installs them. However, this may not happen for the following reasons:
• The necessary codec (typically, a non-Microsoft codec) isn't available on the codec server.
• You have an older version of the Player and your automatic codec-download option isn't enabled.
• The Internet security settings for your browser are set too high.
• You're not connected to the Internet.
If you have an older version of the Player (prior to Windows Media Player 9 Series), you can check your codec download setting by doing the following:
1.
In Windows Media Player, on the Tools menu, click Options, and then click the Player tab.
2.
In the Auto upgrade area, make sure Enable automatic codec download is checked, and specify how often you want the Player to check for updates.
You can change your Internet security settings (if you are logged on as an administrator or a member of the Administrators group) by doing the following:
1.
In Control Panel, open Internet Options.
2.
Click the Security tab, and then click Internet.
3.
In the Security level for this zone area, click Default Level.
If you can’t play the file after completing this procedure, restart your computer, and then try to play the file again.
If you still can’t play the file, try to play another file with the same file name extension. If you can play this file, then there is a problem with the file that you want to play. For more troubleshooting information, see the Windows Media Player Multimedia File Formats Web
Apr 20, 2007 | Olympus WS-100 Digital Voice Recorder
RCA RP5010 Digital Voice Recorder Logo
109 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
