Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Changing belts i need to get to the belt on my washer
  • 639 Answers
Order a Belt:
Appliance & Electronic Parts
NASTASI’S DISCOUNT
APPLIANCE & CONSUMER ELECTRONIC PARTS
TOLL FREE 888-338-3790 (PARTS ONLY)
8:00AM to 12:00AM - 7 DAYS A WEEK
It's not worth fixing if it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Posted on Aug 24, 2008
NEED TO CHANGE THE DRIVE BELT ON GE WASHER
have you got the belt they are a bit tight and need a little stretching before fitting
Nov 27, 2011 | GE WBSR3140DW Top Load Washer
I have a maytag top load washer the washer will drain but will not spin
Maytag washers have two belts one for turning the pump and the other for making it spin. Sounds like the belt for the spin needs to be replaced. It is something that you can do. Maytag washer belts are quite easy to change. Hope this helpedd. Thank you for using Fix ya.
Jun 26, 2011 | Maytag Washing Machines
Washer wont aggitate or spin
If you got some skills and want to learn try this steps.
Get the back guard of the machine out.Start any cycle and look at the motor and belt.If the motor spin, then the belts are loose or need to change them.find the appropriate belt and tension and start again.If the problem persist, i suggest to change your washer.
Nov 01, 2010 | Whirlpool 3362624 Washer Control Timer...
Changed main belt in machine and need to know
check earth wire is on motor, heater element and if metal tub fitted then this will be earthed aswell
Feb 16, 2010 | Electrolux AWW1017 Front Load Washer /...
How do I change the washer belt on a Maytag Washer #LAT2500AAE
I figured out that the belt went on the bottom of the dryer. It was actually very easy to fix once I realized where the belt went. I made the mistake of opening the front cover of the washer first, which is why I did not see where to put the belt. Apparently, if the washer is not level (since I had too much for a load and it caused the washer to pull out from the wall), the belt shook itself loose.
Dec 03, 2008 | Maytag PAV2300 Top Load Washer
BELT LOOSE ON FRIGIDAIRE WASHER HOW TO TIGHTEN
you can't really tighten a belt, I suggest that you change it, although it is extremely hard to replace a a new belt yourself. Have you checked the carbon brushes in the motor do not need changing, this could also generate a burning smell and leave you clothes wet if they are worn.
Nov 15, 2008 | Frigidaire CWS3600AS Top Load Washer
How do I take the front cover off a Maytag MAV4755AWW washer to change the belt for spinning the drum?
Although I'm not familiar with that particular model, most Maytag washers have the belts under the washer (no need to remove the front panel) --- just tip the washer back and check to see if the belts are underneath.
Jun 22, 2008 | Maytag Washing Machines
Belt-washer won't spin
not a fun belt to change on this mahine, thinkin youll need to unmount the motor under the unit to get it on. is it physically broken???
Mar 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Changing a belt
the belt is under the washer. you may be able to reach it if you do not have a cover on the bottom of the washer... if you do have a cover on the bottom than you will need to pull the washer out. and take the back panel of the washer off. from there you will be able to see under the washer. you will be able to see the belt. just release the tensinor and replace the belt....
Oct 20, 2007 | Amana DLW330RA Top Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
95 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
