Question about Kenmore Energy Star 44092 Front Load Washer
Kenmore 44092500 Won't complete spin cycle
Machine passes full diagnostic tests, even spin.
When set to "Drain & Spin", machine will drain, tumble, but shuts down when it should spin and beeps three times(7min left). E47 error code can be retrieved.
Need a door latch assembly
Posted on Aug 30, 2008
AllExperts.com gave me the answer I needed at no cost.
Posted on Jul 29, 2008
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Fisher paykel GWL10 doesn't drain Previous problem
Easy to check the pump but you need to have a bucket handy. Tilt washer backward pump will be on the right side. Remove and clean. Watch out for the water!
Sep 26, 2013 | Washing Machines
My washing machine fills up but the drum is not spinning
Hi calex if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 18, 2013 | Beko Washing Machines
Washer won't drain
DIAGNOSTIC MODE
To enter diagnostic mode follow the steps below.
1. Turn the power on at the power point but off at the machine.
2. Press and hold WASH TEMPERATURE SETTING DOWN and then press POWER until the
machine gives 2 short beeps and lights up.
3. Release the buttons after the beeps as the beeps indicate diagnostic mode has been entered.
4.1 Last Fault Data
When in diagnostic mode the last fault can be found by pressing the SPIN SPEED UP or DOWN
buttons until the HOLD and SLOW lights are illuminated. Binary can then be read from the wash
progress lights.
4.2 Drain Pump Test
MW Washer
When in diagnostic mode press SMART TOUCH CYCLES to activate the drain pump. To
deactivate the pump, press SMART TOUCH CYCLES again.
GW Washer
When in diagnostic mode press REGULAR to activate the drain pump. To deactivate the pump,
press REGULAR again.
4.3 Water Valve Test
The water valves can be activated in diagnostic mode by pushing WASH TEMPERATURE SETTING UP to activate the Hot Valve and WASH TEMPERATURE SETTING DOWN to activate
the Cold valve as with previous models.
Pressing each button once will activate the valve. To de-activate valve press the same button
again. This is also good to use when installing machines as it takes the shock out of the fittings
and seals and allows checking for leaks on the inlet hoses, both machine end and tap or super-tub
end.
Caution: Do not leave the machine unattended when either or both valves are operating
May 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
Washing Machines Logo
414 people viewed this question
Sal De
fordexpert
Robert Rankin
