Question about Toshiba Gigabeat MEG-F20S MP3 Player
Gigabeat Toshiba stalls
My gigabeat mp3player f20 starts loading when i switch it on, goes halfway, the screen starts going into something else then switches back the loading position and doesnt move. help please!!
  • 175 Answers
You r hardrive maybe faulty.
So you'll need to format it. and reload the software.
Otherwise you need to replace the hardrive.
Software here.
http://www.megaupload.com/?d=GTC188NU
Posted on Oct 13, 2008
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
Toshiba gigabeat F20 i 'm getting a system error 000000001, can anyone help and tell me what i need to do???
It's been 12 years since I got my Gigabeat F20 and now I was able to restore it, finally... I found all the original system folders inside and old backup HDD. If someone needs them, please let me know :D
Jun 15, 2010 | Toshiba Gigabeat MEG-F20K (20 GB) MP3...
Installation failed: Loadlibrary error for Gigabeat f20
Hello
Welcome to Fixya's Community.
In Order to solve your Problem you need to repair the Firmware of your Device, to perform that you shoud Upgrade/Repair the firmware.
Please Download and Install the Firmware Updater and follow the instructions.
Downloads
Firmware Updater for Toshiba Gigabeat MEG-F20.
Additional Help:
Toshiba Gigabeat MEG-F20.Mnual Guide.
Thank You for Using Fixya.
Please let me know if you need any Further Info.
Good Luck.
Nov 09, 2009 | Toshiba Gigabeat MEG-F20S MP3 Player
Gigabeat Room Can't Detect Gigabeat on Vista
The key is to have the GB watcher run under XP mode and administrator rights. When you start up the GB Room right click on the program and run as administrator. It runs every time for me. I have the F20.
Mar 30, 2009 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba gigabeat f20
gigabeat_megf0s_mp3_player_204606.jpg Problem with the Toshiba Gigabeat MEG-F20S (20 GB) MP3 Player Toshiba gigabeat f20 ' /* * For text ads, append each ad to the string. */ for(i = 0; i ' + 'Ads by Google' + '' + google_ads[i].line1 + ''; url = '' + google_ads[i].visible_url + ''; info = makeBoldAdWords(google_ads[i].line2) + ' ' + makeBoldAdWords(google_ads[i].line3) + '
'; s += url + info; s += ''; } s += ''; } document.write(s); G_GGL_SKIP += google_ads.length; return; } var G_MAX_ADS_WL = 1; google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#) google_ad_channel = "4447185069+1147946396"; google_ad_output = 'js'; google_max_num_ads = '1'; google_ad_type = 'text'; google_feedback = 'on'; if(typeof G_GGL_SKIP == 'undefined') { G_GGL_SKIP = 0; } google_skip = G_GGL_SKIP; // --> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); Ads by Google Signage Evaluation Kit
www.winmate.com.tw/HD Digital Signage Media Player Windows 7 os,Intel® Core™ i5
Jul 30, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Gigabeat MEGF-20
Your battery has a low voltage.
You need to rejuvenate it.
Jul 08, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
I need help
the OS as been delete from hdd , most of the time 'cause formatting hdd with windows
must have other Gigabeat same model fonctional , or call Toshiba and ask for repair center near you they can copy O.S. back in your Blank hdd .
Hope that help a bit
Regard
262422660
May 29, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Toshiba Gigabeat
try using windows media player it does work if you go to the setting file on yor f20 and slect media player in the pc connections folder
Apr 20, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Gigabeat F20 and Windows Vista
hi i had the same problem and updated gigabeat room to version 3 , not the actual gigabeat just its pc software , and it seems to work ok most of the time but only if i load gigabeat watcher after plugging in my player . hope this helps ,i emailed toshiba uk but they told me that they have no intention of updating the players firmware ,
Apr 07, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Toshiba gigabeat MES60VK (60 GB) stopped working
There is a little battery cut of switch at the bottom of the device. You can unbend a paper clip and switch it off. Then switch it back on after a few seconds. Plug it back into the usb cable to charge it. It should work ok now.
Dec 26, 2007 | Toshiba gigabeat MES60VK Digital Media...
Toshiba Gigabeat MEG-F20S MP3 Player Logo
75 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
