Question about Sony KP-53HS10 TV
Red light flashing 5 times every 2 seconds
The tv i bought in 2000 kp53hs10 color rear video projector . the picture flashes on an off while the sound stays on. the red light in front flashes 5 times an the the picture will go off then come back on. when u are disabled an living on 800 a month u can not afford to send it to the repair shop hope i can fix it my self any help u could give i would apprecaite. thank linda
  • bbgrogan5 Aug 05, 2008
    Same problem..... stand by light blinks 5 times and the entire picture flashes for 10 or 15 seconds every couple of minutes, sometimes worse than others. While watching a DVD it seems the picture doesnt flash as much but the red light still flashes the 5 blink code.
  • Anonymous Aug 13, 2008
    After this problem, I also encountered loss of brightness and some color. All now appears greenish. Any solution?
The flashing red light (blinking 5 times )turning down the brightenss helped had repair man recommended by sony out an check it out he taped on tubes an curcuit boxes same as had been recommend by your sight did the repair man said that over time (bought in 2000)the picture tubes break down an it cost about 250 to 275 to have them referbished because they know longer make them an it would not be ecominal to repair so we will watch it til it goes out then buy another tv it is nice to get an ounist repair man,so thank u for your web site an techs info. i will use u again sincerely lindastar149m ps he covered the red flashing lite with black tape so it would not drive me crazy i had to laugh, cause it just started flashing after he reset the flasher, so no more red flashing light ha haha
Posted on Aug 02, 2008
  • 4,234 Answers
The 5 blink code in dicates a loss of video. There could be a number of reasons for this. I need to look up your specific model to get you the probable parts. Stay tuned...
Dan
Posted on Jul 29, 2008
My sony kp-51ws510 color rear video projector tv when i turn it on it stays on for abt five seconds and then turns off and also the timer and standby light is flashing red
this model did have problems with bad picture tubes---screen goes bright red,green,blue and set shuts down.
set also does this to protect itself---when fails look to see if specific sequence of blinks
Apr 17, 2012 | Televison & Video
Lamp blew, picture went then sound also. Replaced lamp, now will not turn on. Red light flashing on front switch panel.
If the red light flashing 3 times the pause and again flashing 3 times, check and make sure lamp cover is installed correctly back on tv.
Sep 05, 2011 | Sony KS 50R200A Replacement Rear...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Flashing "Standby" light??????
KP53HS10, NO PICTURE OR SOUND , ONLY A CONTINOUS BLINKING RED LIGHT ON CONSOLE. CAN YOU HELP ?
Nov 12, 2009 | Televison & Video
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Sony projector kp53hs10
I recently had this same issue. If you remove the speaker pannel in front of the set, you will see a block with 6 knobs on it, just to the right of the center panel. This is called a focus block. 3 knobs on top which control the voltage going to each tube, and 3 on the bottom are for fine tuning focus for each tube.
If your problem is the same as mine, it is a convergence problem. and due to the fact that the picture is turning off, says that one of the tubes is not getting enough power.
NOTE: BE CAREFUL NOT TO TOUCH ANYTHING ELSE BUT THE FOCUS BLOCK, THERE IS EXTREMELY HIGH VOLTAGE WITHIN THE TELEVISION, AND CAN CAUSE SERIOUS INJURY.
1. Make sure the screen is blank, ex video 2 with nothing on. It's easier to tell.
2. very slowly, one at a time turn up the knob on the left top, should control red, untill you start to see lines come on the screen, then turn back just till they dissappear, and you see a black screen again.
3. continue with the second knob on top, just the same as the first.
4. And continue with the 3rd knob on top right just the same.
5. when you're finished, turn off the set, then back on, let is set for a min or 2, then hit the FLASH FOCUS.
If the problem persists, it most likely is a IC chip.
Best of Luck
Ken
Nov 20, 2008 | Sony KP-53HS10 TV
Standby light flashes 2 or 5 times; lilac picture with horizontal lines; and instant offs
There is some electronic circuit problem with your TV. Best if you want to repair it you find a reputable TV repair shop. Sorry.
Sep 18, 2008 | Sony KV-24FV12 24" TV
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
Sony KP-53HS10 TV Logo
319 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
