Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi ws 55809
Hello, My TV won't turn on. I got the codes and I believe it is a 2, 2
here is what it looks like - - - - - - - - - - - - - - - - And so on til the self test ends. Can you tell me what the code means?
  • 6 more comments
  • dgerade Jul 29, 2008
    I am looking in the back of the TV, but don't see these Fuses... Could they be in the front? Also, it's really dusty should I vacuum, or is there a better way.
    Thanks
    I appreciate the help.
  • dgerade Jul 31, 2008
    F9A04, 05 are not shorted, however F9AO2 and 03 are shorted.
    Is there anyway to test these? Also, I assume I'll have to remove the PCboard to the repairs, do you know of any diagrams which show how to remove the boards, the front end of it (If there are any screws in the front) would be difficult to get to? Any hints?
  • dgerade Aug 06, 2008
    Hello, Disregard the last question... I was talking to two people one asking me for shorted fuses, the other asking for open fuses I was a bit confused.
    After looking at the schematics I removed the board... I can see that F9A04 is open but I'm reading 1.89M ohms. F9A05 is open.
    You said it could be the convergence IC's? Anything else to check before trying to get these parts? Thanks
    So there are two convergence IC's correct? If so, do I need to replace both? Also, do you know where I could get the parts?
  • dgerade Sep 05, 2008
    Hi, I ifnally got the parts and replaced the IC's... Checked the fuses out of the circuit and they were indeed open so I replaced those as well.
    I connected everything back up and hit the power, it shut off again. this time the code gives me a 1, 2... Any suggestions?
    Thanks
    Ok, went back upstairs and tried again after looking at the codes in the manual. the code now is 22 again. DOH! So, any other ideas?
    Thanks
  • dgerade Sep 06, 2008
    I took the board back out and checked the soldering, no shorts... I measured between the pins to confirm this. The code came back as a 12, which is no fault, but this is how it was the last time I tried it and I think trying to turn it on a few times blew the fuses. I just don't want to keep turning it on if it's going to blow the fuses again. Is there anything else you can think of that it may be?
Hi, after lookin in the service manual I have a question. I tested th see if the fuses were shorted, however... I'm not completely sure how these fuses work, since most fuses are shorted to begin with... Are they resistive type fuses of some type? Just looking for insight. Thanks
Posted on Jul 31, 2008
  • Mitsubishi Master
  • 8,617 Answers
22 is short protect usually its the convergence Ics in that model that can short out. check fuses F9A04 and F9A05 if they are open its most likely the convergence ICs that need repslacing. If you need further assistance, please reply to this same post.
Posted on Jul 29, 2008
  • 4 more comments
  • Sonny Berry
    Sonny Berry Jul 29, 2008
    They are not regular fuses. they are pico fuses which look like resistors but dont have color bands. They will me marked on the board with the F9a number
  • Sonny Berry
    Sonny Berry Jul 31, 2008
    There are two possible causes for those two fuses to blow. First would be the Flyback is bad next likeliest is the power transformer T9A50
  • Sonny Berry
    send me an email at slinteriors@yahoo.com and i will send you the diagrams on how to remove the Boards for your model, just remind me which model you need the diagrams for as I get alot of request.
  • Sonny Berry
    Sonny Berry Aug 06, 2008
    If F9A04 and F9A05 are open you need to replace both of those fuses and the convergence Ic as thats whats giving you the 22 error code. The fuses have to be checked out of circuit or you will get a reading on F9A04 just from the surrounding circuit.
  • Sonny Berry
    Yes you have two STK392-570 ICs they both need to be changed the picos are 5 amp picos fuses. You can get replacement ICs and pico fuses at the following link with free shipping and instalation instructions. Here is the link.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    Sonny Berry Sep 05, 2008
    check the solder connections on the IC, as if the two fuses were open the only thing that could have blown them origionally is the IC so if the code is still 22 the ics pins may be bridged with solder or the fuses may not be soldered sufficiently
Tv wont turn on
hold the menu and input/device buttons for 5 seconds and it will blink you a 2 digit code
1-2 normal operation
2-3 i believe is short circuit protection = probably a convergence failure
here is a link to my tutorial
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Jun 20, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55809 goes to white foggy screen occasionally
It will cost between 30.00 - 70.00 dollars to do it yourself depending on if you buy the parts seperate or as kit.
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Where is the STK393-110
This TV uses 2 STK392-570's.
You will not find any STK393-110 inside your TV.
Jul 25, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 2-2 code
look on the center board where the ics are and check F9A04 and F9A05 pico fuses, if they are blown you will need to replace those two 5 Amp picos and the convergence Ics
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mits WS-55809 Convergance prob?
Use high quality IC's made by Sanyo......Avoid Chinese knock-offs
Clean heatsinks off & apply fresh heatsink compound........T.
Nov 07, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi tv model WS-55809
that happened to me and i just gently hit it on the top and it fixed itself
Jun 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809
1)Check for coolant leak from CRT onto signal board
2)Possible convergence problem ..................T.
Oct 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Green Gun does not come on
my tv comes on but it says your input is locked enter your 10 diget code press enter but i dont no it
Jul 16, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
498 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
