When installing Tevion DVB-T Receiver the auto install put up a window requesting - get hotfix... can you explain what this is and how to install this driver?
  • Anonymous Mar 29, 2009
    YES SAME HOTFIX PROBLEM.
  • 12,061 Answers
OK a HotFix is a Fix for a certain problem that only certain situation needs, thus not an overall everybody needs it fix... you need to get the HotFix from Microsoft update site you should have a hotfix number Google for it and download the file, then run the file which will install software on ya PC that will Fix ya issues..
Posted on Jul 29, 2008
My son solved this for me do a google search for this,he installed it and it works fine.
Thanks to those who sent advice.
Regards
Dizzy;-)
AF9015_BDA_Driver-8.6.24.1
Posted on Jun 18, 2009
How do I set up Mitsubishi HD 1080 series television to receive digital channels
Hi, it the tv has an integrated digital tuner it is simply a matter of going into the settings menus available from the remote control and electiong autotune, the set should then serach for / intall the chanels and the you will save the search and that is it...done. The set may have the option of eaither digital or analogue reception in which case you should select digital and then search for the tuning options menu in the settings screen.
For people who do not have digital reception, digital channels can be got by obtaining a digibox, a DVB receiver. This would be connected to the tv via a scart lead. On switching the tv and digibix on the box installation guide will take you through the installation procedure. It is all very straightforward
Jun 13, 2015 | Mitsubishi Televison & Video
Message on screen says please check aerial or local dvb service availability, press OK to start auto set-up - but this doesn't help
The message indicates that the TV is not receiving a signal from either the external tv antenna or from the cable company. So, if you have cable, and it is correctly connected to your TV, you need to call the cable company for service. Once you have a signal, THEN you can run auto setup to capture the channels to your set's memory.
Jan 07, 2010 | Panasonic Televison & Video
Digihome digital terrestial receiver Model DVB 915 I sitched the TV set off at night and then turned off the electric switch at the wall socket for both the TV and Digi Box. Next day the digibog...
hello make sure power is off take the top off the digibox see if you've got a glass fuse inside if the fuse is black its blown .where the fuse is holders is it should say what the fuse is rated at ie 1.25 amp put a fuse in with the same amps if it blows again then you have a dead short in the circuit good luck
shaun
Jul 21, 2009 | Televison & Video
I need tow download the manual for my dvd recorder which is a tevion dvd recorder Hdd with g code access. I bought it from cash converters and it doesnt have a manual
I have successfully found manuals for Sony TV and a Pioneer auto radio on Google. I entered the brand followed by the complete model # followed by owners manual. Give it a try and good luck.
Jun 21, 2009 | Televison & Video
I have bought a remotec universal remote control that I cant seem to get to work on my Tevion TEV374 television. I have tried the 2 codes that came in the book and also an additional 7 that the **** smith...
THEY ALL HAVE AN AUTO CODE SETUP.WHERE YOU SIT THERE AND LET THE
TURD RUN THROUGH ALL THE CODES .lOOK UP CODE AUTO SEARCH,ITS THERE IN THE BOOK!
Feb 03, 2009 | Televison & Video
I have a HDTV DVB-T PLUS and I have installed the software/hardware as per instructions but on the odd occasion an error window opens and states that windows has detected a problem and needs to close down,...
just kept looking on google and finally someone had posted a solution, hopefully it works. It seems ok at the moment and has no crashed since doing it.
Dec 06, 2008 | Televison & Video
Tried to install hdtv usb receiver disk onto windows xp. Keeps telling me to install hotfix. What does that mean?
Ok, I've got it sorted now. The driver that came with the TV stick doesn't like XP SP3.
I found this out there on the internet - not on the supplier web site though:
http://www.augustint.com/download.htm
This version of the driver likes XP SP3
http://www.augustint.com/download/AF...r-8.6.24.1.exe
Aug 03, 2008 | Televison & Video
System error found Divio Fusion hdtv Software dvb-t version 3.68
system error found Divio Fusion hdtv Software dvb-t version 3.68
Solution:- Re set drivers off the Divio Web Site,the installation disk that came with the product was out of date being an earlier version.
Two attempts were made to install new up dated drivers,incorrect product description was selected from off the list at first before correct description in the 3.68 version was selected
globalpage
Jul 17, 2008 | Televison & Video
Need a remote control for a tevion pvr 1620
The website (remotes.com) sells Tevion TV remote controls. Their tolfree number is 1-800-REMOTES.
Jul 09, 2008 | Televison & Video
Medion dvb-t tuner expresscard 54 ctx967 v7.2.2 have tv guide but window indicates hardware not detected any ideas using vista premium
I have a problem with my tv signal, and it started when i had a problem with my system so i had to farmat the system and now i can't receive any signal again from from my DVB=T and i have tryed to reprogramm with no avail.can any one help me solve this problem?Thanks
May 12, 2008 | Televison & Video
Televison & Video Logo
1,102 people viewed this question
Top Televison & Video Experts
Electro Med Services...
