Question about Hitachi 53UDX10B 53" Rear Projection Television
Double images What is wrong when images and text are doubled and screen is pink and green when turned on lasting 1 hour or more?
    Sergeant:
  • 291 Answers
You could have some type of convergance (three colors, three guns) problem. Also a misaligned horizontal or vertical oscillator.Ceck to see if any of tiny magnets around the bell of picture tube or next to coils in and around bell of pix tube are missing.
Posted on Jul 30, 2008
Pink and green color out of focus people have one green hand extended with another pink hand double exposed features. Tried to adjust the color convergence and it won't work and it is all out of line and...
The mirror that projects the image on the screen from the lights below is most likely out of alignment, this is a very delicate adjustment to make. If your not familure with doing this, it will need to go to a shop. I hope this helps, if you have any other questions please contact me. Good luck.
Sep 23, 2009 | Toshiba 43H71 43" Rear Projection...
Pink and green lines and double picture on Samsung big screen tv.
Replace the main bd. Have a trained Samsung tech troubleshoot to confirm.
Jul 08, 2009 | Samsung LN40A650A LCD TV
Hitachi big screen tv
if ths image is stuck on screen the solution should be white wash
Mar 01, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Lightning? Can it be fixed?
sounds like the convergence ICs and resistors due to the double image. You need two convergence ICs both STK392-110 ICs and the following six resistors. (2) 3.3 ohms 1watt resistors, (2) 1.8 ohm 1watt resistors. (1) 1.8 ohm 1watt resistors. (1) 3.9 ohm1watt resistor. You can get replacemnet ICs and resistors at the following link and they provide free instalation instructions so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Aug 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Pink and green colors on screen when first turning on tv lasting 1 hour +
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
Jul 29, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Double image on green
Focus won't help if it is a double image. Sounds like convergence amps need to be replaced. Very typical on these.
Jul 04, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Double image 6 your old unit
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 25, 2007 | Hitachi 61UWX10B 61" Rear Projection...
WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Oct 15, 2007 | Mitsubishi WS-55711 55" Rear Projection...
Sony KP-57WS500
the unit needs the convergence ic's replaced and probably a couple of safety resistors.average repaire are about 300 from a tv shop
Mar 04, 2007 | Sony KP-57WS500 57" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
87 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
