Check a couple of things before you run out to get a new scanner.
Is there a power switch on the scanner? Often, the switch is hidden toward the bottom on any of the 4 sides of the scanner. Try switching it forward, then back again.
Also, have you tried plugging the scanner in to a different outlet? A different room?
Good luck.
Since the power cord works on a different scanner, this means the power supply unit inside the printer has failed. In most cases, this costs more to fix/repair than a new printer.
Testimonial: "Thank you very much for your valuable support for free of charge!!! More power and blessings to come!!!!!"
