Question about HP Office Equipment & Supplies
My PSC 1300 series printer fails to print photographis paper. I have tried various settings from the print sub menu's to no avail. The paper I am using is FUJIFILM premium plus photo paper 235 g/sm. Thanking you for your assistance Barry Seabourne
  • 2,427 Answers
Well chances are that
1. you are using compatible ink cartridges which the ink latency if off and it wont work with the paper
or
the paper is defective (YEP TRUE PAPER CAN BE) normally this will occur if the chemical they are coating it with is the wrong mixture or amount ,, of if the paper is a cheap knockoff..
Try printing on a different type of paper
If this isnt your problem, please describe what is happening in more detail
Posted on Jul 29, 2008
  • 4,472 Answers
What do you mean by it doesn't print? What exactly happens when you try and print?
Thanks,
Lee
  • Lee A.
    Lee A. Jul 29, 2008
    Have you installed the drivers, does it print with regular paper? Can you print from the printer at all? The more information I get the better I can assist you.
    Thanks,
    Lee
How to make the printer regognise taht there is paper installed?
Have you tried resetting this from the print menu on your PC screen? i.e., tell your printer to loook for A4 paper. Maybe there's a miscommunication between the PC and the printer???
Jun 09, 2012 | HP PSC 2350 All-In-One InkJet Printer
I have a 1300 printer series. When I go to print a 5/7 photo the menu that comes up for paper size does not have a setting for 5by7 what do I do?
See if there is a download on the hp website for that printer model, 1300, they probably have a printer software download that should have all the paper sizes you need, specifically the 5x7 inch.
try this link out, its for laser printers, not sure if yours is a inkjet or laser..
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?locale=en_US&taskId=135&prodTypeId=18972&prodSeriesId=238320
hope this helps
Jan 25, 2011 | HP Office Equipment & Supplies
How to print borderless 5 x 7 pictures using an HP psc 1310 series printer I'm using 5.0" x 7.0" hp premium glossy photo paper and a hp psc 1310 series printer and i cannot align the paper properly to...
Open printers window, right click on the psc printer icon , select printing preferences, click on paper\quality tab, select the paper size as 5x7, check the option as borderless printing and click on apply and then oK...
Try to print ,,,
Dec 07, 2009 | HP PSC 1315 All-In-One InkJet Printer
How do I get a alingment test
HP PSC 1200 and 1300 series:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP psc 1315 tries to downloads wrong drivers
HP has two sets of numbers for the printer.
1315 - This is your model number
1300 - This is your series number
The software, manuals, printer queue, etc. will all show the printer under your series number. This is because there are several models that have minor differences that are not related to the software so they will all share the same software. When you try to download the software for your OS you will use your model number and when it has downloaded during the install it will all show as the series number again. This is normal.
Jan 14, 2009 | HP PSC 1315 All-In-One InkJet Printer
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Nov 12, 2008 | Dell 3100cn Laser Printer
FUJIFIM Premium Plus Photo Paper 235 g/sm Jams when printing.
Fuji paper is the arch enemy of the hp printer due to it's high gloss and the slickness of the paper - try another brand of paper. It sounds like a money grab but hp paper has a special marking on each page that is read by the printer and it often errors much less.
Jul 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 950 problem
Look in the printer software on the computer for paper size settings. If that doesn't help go into the settings menu on the printer it self. If you have HP Setup Assistant on your computer, use that to reset up your printer to your computer.
May 30, 2008 | HP PSC 950 All-In-One InkJet Printer
Hp psc 950
Reinstall the driver. There is a possibility that the divice driver is corrupt.
Jan 08, 2008 | HP PSC 950 All-In-One InkJet Printer
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
      5. Press Copies .
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
