Question about Goodman CLQ36AR49 Air Conditioner
A/C unit shutting off when hot
With regard to my previous problem. My a/c man is coming tomorrow to install a hard start kit for this ongoing problem. Does this make sense?
  • bestsource Aug 01, 2008
    He has not come to install the hard start kit yet. A/c keeps shutting itself off. Coils have since been cleaned. Any ideas please.
Repair man has not been round to install the hard start kit.
Someone suggested replacing some wiring and checking running amps, but can't get the guy to come back around.
Really I need a Goodman rep to help out, but they will only talk to a licensed tech. My unit is a Goodman CKL 49-1
Posted on Aug 04, 2008
    Scholar:
  • 121 Answers
A hard start kit will not keep your unit running when it is hot or overheating. Did you get any different results with the hard start kit.
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
Why won't my compressor on my dometic not come on?
It really makes no difference what the AC unit is in, it's still AC. I've come across this situation many times, and found that unit is just low on Freon. Once, and only once, I hound a loose thermostat connection at the unit, so the compressor didn't know it was supposed to come on. Nonetheless, Check the connection AT the unit. If good, you'll have to get an AC man to recharge it because the charge line end is soldered shut. IF by chance there IS a fitting with a plastic cap on it, like on your tire fill, get a recharge kit with connecting line and recharge it with ONE canister of Freon. Get the kit from auto parts distributor, remove the plastic cap from the AC charge line, open the piercing valve on the kit line and connect to the can. DON"T pierce the top yet. Connect the other end to the AC charge line finger tight, now pierce the top of the canister with the T-handle/knob AFTER starting the AC to suck the Freon into the system and screw the piercing pin back out part way to release the Freon. NOTE: To get all the stuff out of the canister, stick the canister into a bucket of hot water you took up with you. Once the canister is empty, remove the kit line from the charge line, trash the empty, hide the kit line somewhere in case needed again(won't have to buy another kit, just Freon bottles), put the unit cover back on and stay cool.
Aug 17, 2014 | Dometic Rooftop RV Air Conditioner
Delfield mini freezer for restaurant is not freezing. Unit has power and cabinet fan runs but comp tries to kick on then you here a click and it immidietly shuts off before it can really ever start. Hi...
Compressor is locked up. You have an outside chance of getting it to come back if you install a hard start capacitor. When a locked compressor tries to start it gets hot really fast and kicks the power off to prevent wires from overheating. You can get a hard start kit from wwgrainger or refrigeration supply company. Many times they won't sell direct to the end user. The hard start kit gives it an extra boost when it tries to start. Most times this won't work. Usually the compressor has to be replaced because it is burned out internally. The hard start kit is less than $20.00, so its worth a shot.
Sep 21, 2010 | Delfield Freezers
ASUS p4p8oo-E shuts down
Does it feel hot? Could be the hard drive.
Try scanning the hard drive using this method.
May 22, 2010 | ASUS P4P800E Deluxe (90M8LCW0G0EAY)...
Unit shuts off as soon as it is plugged in
Hard start Kits are attached to a compressor wiring to give an extra amount of electric current to the compressor motor. You will need someone more familiar with refrigerator wiring to do this. Hard Start Kits are available at refrigeration parts houses.
Aug 24, 2009 | Refrigerators
Intertherm S3QA042K compressor won't restart
You probably need a hard-start kit. A hard-start kit connects to the run capacitor and provides a starting boost for your compressor. If you install a hard-start kit, monitor your a/c for a while because it is possible that the bearings in the compressor are going bad.
Jul 30, 2009 | Heating & Cooling
I just had a bryant a/c installed (txv) should it have a hard start kit as well.
Anytime you have TXV they do need a hard start kit. The TXV shut down on the off cycle and does not allow unit to equalize. Rusty
Jun 11, 2009 | Goodman CLQ36AR49 Air Conditioner
Reverse Cycle not cooling!
I had a service man come out and he said the compressor was not coming on so he installed a hard start in parallel with capacitor solving the problem and is working normal now.
Nov 30, 2008 | Heating & Cooling
Hard Starting Dometic Rooftop AC unit
Just add a$10:00 hard start kit to the compressor.
Sep 06, 2008 | Dometic Rooftop RV Air Conditioner
Travelmate 4003LCi
try hooking it to another monitor.
Jan 26, 2008 | Acer TravelMate 2300 Notebook
Goodman CLQ36AR49 Air Conditioner Logo
324 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
