Open Firefox, Click on Open Menu Option in the right hand top corner of the screen, then click on Add-ons in the search box type Video DownloadHelper and click on Install. Once done, you will see and icon in the right hand top corner which is red/yellow/blue color
Plug in the webcam TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices' To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
If your webcam has a built in mic make it the default mic Plug in the webcam TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
Try setting the webcam mic as default Plug in the webcam TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
Check Plug in your webcam TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. Right click on volume graph and check 'Show hidden devices' and 'Show disabled devices' If you have a webcam mic it will now be displayed. To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Interrogate the information in your 'Recording' file
Plug your webcam in TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab.- check both "Show disabled" and "Show disconnected" Right click on volume graph and To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
The webcam capture utility is probably running at the same time as you are trying to use instant messaging. Is the webcam icon in the bottom right hand corner? If so right click and close. Then open messenger or whatever and run audio/ video set up.
Open up you webcam program and then locate the webcam icon in your system tray (icons by the clock lower right hand side corner) then right click on it
There should be a Option or a Settings button
You should be able to acess a picture/video configuration from there
