Question about IBM ThinkPad T40 2373 Notebook
Re: t40 ibm fan error
The fan is a known good fan, the fan worked in another laptop. i can not do the download to clear up the bios because i could not even boot up the laptop because of the fan error. please advise
The laptop shuts off before it can even boot up to the boot disk (cd drive), so i am uable to enter the boot menu. still get the fan error, then would shut off, will not even stay long enough to boot to the cd boot disk. pls advise.
both the original and the replacement fan were known good (tested on a working laptop)
Posted on Jul 29, 2008
    Genius:
  • 2,028 Answers
Are you talking about the original fan being good or the replacement? If it's the original, then your problem may lie with the processor or mainboard. Try the download first, you will need to access another computer to make a bootable disc for the download to clear it. I believe with IBM you can make a bootable floppy or CD. If you have a floppy for your machine, some don't. Once you've made the disc or floppy, you will need to enter the boot menu, and boot from the proper drive. I'm out for the night, but I'll be back in the morning. Let me know.
I need to rest password in bios
Removing the RTC battery and leaving it uninstalled for 5 or more minutes causes all passwords and CMOS settings to be cleared. BIOS password can be removed by temporarily disconnecting/ removing the RTC/ CMOS (Coin-cell) battery from the motherboard.
Disconnect the coin-cell battery from the system board and it will reset the BIOS to its default setting and the password would be gone.
Please Refer to Page 29, 106 & 79 of the REPAIR MANUAL IBM T40 for Battery removal, keyboard removal and RTC battery removal instructions.
The Backup Battery (RTC, CMOS) is located under the keyboard. So you have to remove the keyboard to access the battery. The above Manual from IBM shows the exact method/ instructions and pictures for laptop dis-assembly for the purpose.
If you are comfortable with working inside such electronics, you can't do it yourself, or else you may seek help from local laptop service professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 21, 2011 | IBM ThinkPad T40 2373 Notebook
BIOS locked out on IBM T40 and T42
visit this page to answer your problem. God Speed
Apr 07, 2010 | IBM ThinkPad T40 2373 Notebook
My IBM T40 does not support audio drivers,help
1) Be sure that the audio is turened on in the BIOS (if there is such an option)
2) Go here and download and install the audio driver for your laptop:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-46258
Mar 23, 2010 | IBM ThinkPad T40 2379 Notebook
Remove Bios Password ibm t40
ON YOUR WINDOWS ENVIRONMENT open command prompt, or MS DOS prompt type this:
debug
o 70 2e
o 71 0
q
Then restart...
Oct 21, 2009 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 PC Notebook error 1802: unauthorized netword card isplugged in my laptop cannot boot because of this probs
This is ussually caused by an unsupported WiFi card being installed. You can correct this problem by using a quick BIOS hack... (If you are getting the 1802 error)
Go to this site for the fix: http://www.command-tab.com/2006/02/26/thinkpad-1802-error-fix/
Jan 26, 2009 | IBM ThinkPad T40 2373 Notebook
I'm trying to clear the bios password on my girlfreinds thinkpad t40.... I've removed the cmos battery and was going to leave it out for an hour or so ....... will this work?
An easier solution is to use a backdoor password for your laptops' model to clear out the bios password. For IBM, the backdoor password is merlin
Dec 03, 2008 | IBM ThinkPad T40 2373 Notebook
Boot problem
check it on bios whether the hard drive is detecting or not, if detecting then recover OS using recovery Cd
Nov 15, 2008 | IBM ThinkPad T40 2379 Notebook
IBM T40 screen not working!!!! Please Help Me!!!!
check the display on external monitor, through the vga port of your laptop if the display is there then its the problem of your screen, some times this happen due to non working of the cable that gives display to the screen , its better check it by some technician
Nov 03, 2008 | IBM ThinkPad T40 2373 Notebook
T40 2373 ibm fan error
One of three things; 1- when the fan codes on some IBM's, the code locks in the bios, there is a download the has to be ran in order to clear the code and the machine to run properly. Check IBM's support site to see if this is the case for your machine 2- If the machine overheated in the process of the fan going out, then the processor may have been damaged, causing the problem and 3- if there was a malfunction with the motherboard which initially caused the fan to stop working, a new fan won't work either. Test the old fan by hooking power up to it, it is power direct and has two leads positive and negative, when power is applied it will run or not. If it does run then the problem is with the motherboard. Try these and get back to me.
Jul 29, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
286 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
