Question about Whirlpool 24 in. GU2548XTP Built-in Dishwasher
Getting very close
I think you have helped me isloate the problem. When I press Accusense, the display shows "- - " which as you told me means it is not latched. I was able to push in several spots and get the latch to accept and the washer worked once, but can not get it to start again. The washer is latching, but not allowing it to start. I opened the panel and saw the latch mechanism. It works and pushes down two sensors. How do i detemrine which one is faulty or could it be something else?
  • map12c02 Aug 03, 2008
    I took a multimeter to the switches and they both seem to work. The sensor on the left measures 5 volts when depressed and the sensor on the right measures 120 volts and 0 volts when depressed. Any other things that would make the washer intermittment?
    Genius:
  • 2,035 Answers
Its the door sensor which is creating the problem its better to replace the two sensor on the dishwasher to get it fixed ...
Good luck.....
Posted on Jul 29, 2008
Display shows door not closed for self cleaning when door is closed
think it means lock door . there might be a sliding lever between the cooktop and oven door slide it to the right .
Feb 20, 2015 | GE JKP20 Electric Single Oven
Hello, I am using samsung GT C6712 and it always says that "pc connection only available in idle. Please close some application". It then told me to press the end keys to close samsung kies. After pressing...
Hi, Have you got your problem fixed by any means? If yes, could you drop the solution please? I have now the same problem for the last couple of days. email me @ gova.bn10@gmail.com
May 10, 2013 | Cell Phones
Can't find a manual online. What does 5/4 mean, and how do I turn it off? Same for E. My biggest problem is that when I add up numbers with the print function on (for depositing large batches of...
The manual for the Canon P1-DHV is online at http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf>.
When the display shows "5/4", the calculator is doing 5/4 rounding which means: 5 or above round up, 4 or below round down. To control rounding press the "5/4" key.
When the display shows "E" the calculator could not complete a calculation. It can be because of dividing by 0, or because the total exceeded 1 trillion, or because the operator entered calculations faster than the calculator could complete them. Press the CI/C key to clear it.
I can't explain why you are not getting a total on the tape. Try the following example from the manual exactly as shown, and let me know if your tape shows the total.
  1. Clear the calculator (press [CI/C])
  2. Choose 5/4 rounding (press [5/4] until "5/4" displays)
  3. Choose add mode (press [DEC] until "A" displays)
  4. Choose cost-sell-margin mode (press [B-T] until "B" displays)
  5. Turn printer on (press [PRINT] until "PRINT" displays)
  6. To calculate: $12.55 + $15.75 - $5.30
  7. Key in: 1255 [+] 1575 [-] 530 [=]
  8. Tape shows: [0. C] ... [12.55 +] ... [15.75 -] ... [5.30 =] ... [23.00 *]
Apr 07, 2011 | Office Equipment & Supplies
Washing machine shows key on the display and won't start
Hello, Welcome to fixya.
The Key symbol means the lock has been activated some how.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry and good luck going forward.
Regards,
Macmarkus :)
Oct 20, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Accu sense Light keeps flashing and dish washer wont do anything. help
Under the dishwasher there is a 'kickPlate " turn the power off to the unit and there are 2 screws holding the kickplate on behind it there is a Book ( Tech Sheet ) that will tell you what the accusense lighting means. I thinks it mean you have a bad heater circuit tho which is either a bad heating element or control board. It could possible be the sump motor assy too.
Any qusetions feel free to ask hope this helped
Phillytech1
Aug 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have a top loader and i have been getting an LL error
I would next check the TDS. Are you taking the error in Spin Cycle of the wash cycle?
Let’s do this quick check and see what you get for test results.
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 of the SM for the details.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
What are your results?
Rich
Mar 14, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer keeps getting dc code, doesn't matter how big the load is. Have unplugged the machine and moved clothes around but it still keeps doing it.
Most of the time this is a clutch malfunction. If you feel you can DIY after reading this post we will try to help.
I always recommend folks to check the Tub Displacement Sensor its fairly easy to do thru the washer lid.
Some handy links the Service Manual for reference. Sears Parts Direct for reference.
TDS check from the SM slightly modified;
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM. This done thru the lid.
a. Enter Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
e. Press Hand Wash.
If you get these results your TDS sensor should be just fine.
You can pump out the excess Tub water with this process from the Service Manual;
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Turn off the drain pump with twith the off button or hit the Presoak key.
Poat back if you have questions or concerns....Rich aka dh1200s
Nov 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Closed caption
Closed caption wont turn off was solved by Bresnan tech. He told me the only way was to push the power button on my remote & then push the menu button right away & it would bring up a white screen & cc would be on it. I could't get it to work so I pushed the power button on my remote & the menu button on my motorola cable box & up came the screen & closed caption was on it. I disabled it & it took off the closed caption. Hope this helps
Dec 26, 2007 | Protron PLTV-32 Television
When the cover is lowered for an extended period, and then
when you close the lid it will hibernate, pressing any key does not work, you normally have to press the power button and it will power back up and show the screen and the running programmes, i think you are getting confused with sleep mode where the pc can wake opn keyboard.
Nov 05, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Outside display screen will not show anything but the motorolla logo
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
or:
Menu > Settings > Personalise > Home Screen
Nov 01, 2007 | Motorola Mobility RAZR V3
Whirlpool 24 in. GU2548XTP Built-in Dishwasher Logo
73 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
