Question about Kenmore 63942 Dryer
Guy at Sears parts said
That thermal limiter (no fuse just this) is not likely the cause of no heat in running dryer. . Dryer will not run at all when that blows. He said safety thermostat most likely culprit. (don't know if he turns a wrench or just looks in books)...true or false?
  • patslacke Jul 31, 2008
    thanks - I decided to buy a clothesline!!haha I cancelled Sears guy after I went to Sears parts and none of these items is in stock. Furthermore clerk checked and if any of these are the cause the maint guy would have to order as well. What's the point of that? The clothesline will work for the summer and fall and by then I'll have found/ordered these parts.
  • 550 Answers
Safety thermostat, IS, thermal limit, IS thermal fuse, IS overtemperature cutout,
and probably half a dozen other names for the same item
The most common cause is burn out of the thermal cut-out. These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
Clean the exhaust ducts all the way to the outside wall, lots of vent hoods block over time. then examin the exhaust duct for devices that look like this guy at Sears parts said - 2832e78.jpg or like this a5b1531.jpg with wires connected to the terminals. there may be 2(hi lo), test with a flashlilght bulb & battery, or ohmmeter
conductivity good,
no conductivity, replace,
they are not resettable.
There are only a few different kinds the local parts guy will have them. take the dud one for him to match.
Remove the plug from the wall before doing anything, remove the wires from the terminals before testing.
This a187dee.jpg is is the circuit for a kenmore dryer 24032,
220V overtemp cutout in the bottom right corner, is NOT connected to the 110V motor circuit.
The motor still runs when the cutout has blown
Sears sells you a $20 part,
arranges a $200 home service call,
somebody gets an attaboy for upsaling
Posted on Jul 31, 2008
  • AlmostBob
    AlmostBob Jul 31, 2008
    tell sears to *expletive deleted*
    Kenmore dryer parts can be found at your local parts guy or onlline at,
    they are mostly rebadged ge anyway
    the thermal cutouts are pretty much a standard item, 3 screw patterns and 2 temperatures
  • AlmostBob
    AlmostBob Aug 10, 2008
    this is from another post
    Indicates you can ignore the Sears tech, they can't fix their own stuff, so they definitely cant fix yours
    • kenmore 2.1 cu. ft compact top loader washer will not stop filling! im a sears tech, change computer board because that was main problem( 1out of 2 )changed board which is just below the the overlay panel with the light display only. pressure switch is well in tack as far as wireing. and the air hose is well connected to tub & pressure switch. what could be the problem? should I the tech have changed all the electronic boards or is the pressure hose & switch deffective! because they seem to be good . could u please send me the techincian test cycle for this model Kenmore 2.1 compact portable top loader
My dryer is not heating up, I did replace fuse but sstill no heat
The thermal fuse is not a part of the heating circuit which is composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on link below for the detailed troubleshooting and repair.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 21, 2011 | Dryers
Roper electric dryer will not heat after replacing heating element and thermal fuse. what's wrong.
It doesn't necessarily mean the heating element is busted when the dryer stops heating and the thermal fuse is not part of the heating circuit, it is part of the motor circuit. The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions. Indicate the exact model number of the dryer should you need further assistance.
Feb 12, 2011 | Dryers
The dryer runs but doesnt heat. I pulled the heating element and took it to be replaced. The parts place ohm'd out the element and said it was fine. They sold me a small white fuse which i replaced but...
The skinny white fuse blows and the dryer won't run at all.
The small limit in this kit is most likely gone out.
That limit right there to the right of my hand is the problem most likely.
Service manual and more is HERE
Feb 03, 2011 | Roper REX4634KQ Electric Dryer
Whirlpool model#LEQ8000JQ3 will tumble but not heat up. Vent is not clogged all the way out. Also how old is this dryer?
Maybe what 5, 10 years old at the most. Unplug the dryer and look for air blockages. d404494.jpgThat will give you a clue if it is the heater element or the limits mounted on the heater chamber. Overheating causes these guys to kick out. 012813e.jpgThe dryer itself will still run. If their is severe blockage to the filter housing the thermal fuse will get in the act and kill all power to the dryer through the door circuit. You say it runs so ts get down to the nitty gritty. bc32dd7.jpgUnplug the dryer and take the back dust cover off. There you will find the heater and limits on the right and the filter chute and blower with thermal limit. Lets look at your heater1c9285f.jpgIt mounts on bottom and easier to take out than older ones was16e16c9.jpg
Jul 24, 2010 | Whirlpool Dryers
My dryer has no heat
If the model number you posted this question under is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
You can refer to the following parts illustration for assistance:
The components are listed as follows:
Heating Element (Item 17)
Thermal Cut-Out (Item 6)
Hi-Limit Thermostat (Item 15)
Internal-Bias Thermostat (Item 20)
Thermal Fuse (Item 19)
If you need assistance on how to troubleshoot a dryer, you can refer to this link:
The MOST common causes of heat related problems: 1. Blown Thermal Cut-Out. 2. Missing 1/2 your input voltage at the wall receptacle (the dryer will still run with half the voltage missing, but won't heat - double check your source voltage at the receptacle and/or your circuit breakers. 3. Bad power cord, causing 1/2 the input voltage to be missing. 4. Blown heating element. Read through all the information provided and let me know if you have any questions, or need further assistance. I hope you find this information helpful. NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
Apr 02, 2010 | Whirlpool LER4634J Electric Dryer
For Dryer Model LER7646EQ1, dryer runs but no heat, It could be the heating element, the thermal fuse or other. Also the dryer has been running hot.I do not know how to remove the front panel
This sounds like a faulty thermal fuse or heating element. The fact that you said the dryer has been running hot could indicate that the heating element was making contact with the heater box or the high limit thermostat is faulty. Both the thermal fuse and heating element can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity means a faulty component. When necessary to replace a thermal fuse it is best to change the high limit thermostat as well. They will sometimes come as a set from a parts supplier. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 23, 2009 | Whirlpool LER7646E Dryer
Dryer wont start
Okay...your dryer is one of the more easier dryers to access the heating circuits. All you have to do is unplug the dryer and remove the back panel. The heating circuits will be on the right hand side (as viewed from the rear). The heating element is inserted inside the heater box with the thermal cut-out (TCO) mounted on the top portion of the heat box. The hi-limit thermostat will be located adjacent to the heating element ceramic terminals. You mentioned a thermal fuse also. It is a small white plastic (sometimes gray) looking component mounted on the blower fan housing on the lower left hand side of the dryer (as viewed from the rear).
If the dryer does not run at all, the THERMAL FUSE is a good diagnosis on your part.
If the dryer runs, but does not heat, the THERMAL CUT-OUT, heating element or hi-limit thermostat are your likely problems.
The following link provides you with some necessary guidelines on how to troubleshoot if needed:
Most dryer problems are related to overheating caused by poor ventilation, or overloading. If you need a drawing of your dryer heat components you can reference Just type in the model number you provided (include the prefix "110", this identifies the manufacturer as Whirlpool). The number should be written as follows: 110.66801691. Look under the "Bulkhead" heading for an exploded view diagram of your dryer. The Thermal Fuse is listed as item 59 (part #3392519). I hope you find this information helpful. Let me know if you have any questions.
May 03, 2009 | Kenmore Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Runs but no heat
most common cause of no heat is a blown thermal cutout, over temperature cuthout, thermal fuse (any of a dozen or more names for the same article
examine the exhaust vent ducting inside the dryer for screw on device that looks like this d7573a1.jpg or this 0874a9a.jpg, with wires on the terminals. they are not resettable but they are cheap. despite the large number of dryer models there are only a few cutouts, used in multiple dryers, the local parts guy will be able to match it easily.
test with battery annd bulb, or ohmmeter
conducts-good, no conduct- replace
if you havent disposed of them already, retain the heater and thermostat, they are probably good, and will make spares if the parts guy wont buy back the replacements
Aug 29, 2008 | Kenmore 63942 Dryer
Runs but no heat
i have replaced TH2 in my dle0322 about 6 times now. It never lasts more than a month. What could be causing this?
Apr 21, 2008 | LG DLE2532W Electric Dryer
Kenmore 63942 Dryer Logo
118 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
