Question about AOpen MA-691 Computer Speakers
Output voltage of 120volt AC brick & approx dimensions
I live aboard ship and have 12 volt DC available up the kazoo. I need some physically small powered speakers I can do a cord-ectomy on the brink and tap 12v DC direct off the ship’s power.
Trust me I have an audio input powered by 12 volts so when we are under sail I don’t need the AC power.
Also what are the approx dimensions +/- ¼ inch.
  • 12,061 Answers
Any PC speakers that have a AC plug pak attached can probably use 12V simply cut off the AC plug packs lead that goes to the speakers, and connect up 12V ya should be good to go.. some connect with a Phono Plug, and usually the Outer is Minus Voltage and the Centre is Plus Voltage .. they are also generally Diode protected so a reversal shouldn't cause too many probs... GL
Posted on Jul 29, 2008
It will not trurn on does the ac adapter need replacement it is over 10 yrs old
Look at adapter, see what output is supposed to be- maybe 12 volts DC? Find a multimeter that will measure DC voltage, and see if the output plug has that across the connector. If you have an ordinary power cord without an adapter, it will have 120 volts AC like any other cord, which you can also measure on AC scale, but be careful as you can get a dangerous shock, just like you can from an ordinary household outlet.
Note: AC voltage may vary by country.
Apr 09, 2014 | Canon PIXMA iP3000 InkJet Photo Printer
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
6 Volt dc 4w charger for Omron blood pressure unit
You can use a multi voltage mains adapter for your Omron. These are available at electronic stores ot on the Internet. Make sure it is a DC adapter and switch to 6 volts also make sure the power connector is set correctly to the polarity of the Omron power socket.
Nov 30, 2012 | Omron Health & Beauty
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
I am installinga 4548 inverter. At 4500 watts, it puts out approximately 20 amp per phase. My generater that will feed the charging current for the batteries will put outapproximately 28 amps. Is the...
Let just wait a minute. You have an inverter that is rated at 4500 watts. This spooky. The inverter has a three phase input/three phase output? What is the inverter going to be used for?
Next question. What type of batteries are you using and what is the voltage/current in series or parallel? What will be the total voltage you will producing with the batteries? What is the total current of the batteries.
Another question? What is the voltage of the 28 amps? If it going to dump 28 amps across some batteries that rated at 12 volts and 1400 amp/hrs. For 12 volt batteries with a total of 1400 amps. What you will need approx 14 to 14 1/2 DC and with 28 amps across the batteries for charging these batteries. The batteries will be gone in about 1 hour. Boil all the water out of them. When a battery starts to boil it release water with hydrogen gas (the gas is very explosive and dangerous).
You also don't have a regulation circuit to limit the amount of current depending on the needs of the batteries. Also, you don't have a trickle charger to keep the batteries fully charge when the batteries are idle.
You will also need DC regulated charger that will keep the voltage 2-4 volts above you battery voltage. Without this voltage above the batteries voltage it will not charge those batters. Batteries need to forced to except a charge that why voltage above the source voltage. If you can check the voltage on your car/truck with a 12 volt system. While engine is running the voltage across the battery will be 13.8 to 14.1 volts. Now, the current limiter is the alternator it has a regulator built into it for stabiizing voltage and current went the batteries require more current but it limited by alternator regulator
Now, to get more current out of the alternator the regulator will supply dc voltage to the stator of the alternator generator more current. More dc voltage is supplied by the regulator but the dc voltages is limit to about 24 volts. Another limiting factor is the alternator copper windings diameter---larger diameter more current, small diameter less current. Utilities systems use big mega watts generators. The maxi um dc voltage for these three phase generator would like 500 to 800dc volts for peak to peak output. There is a simpler way of doing this.
You need to rethink everything here. Also, I can help you if you supply the needed information.
I truly wish you luck in your electrical endeavors. GB you. stewbison
Aug 22, 2011 | Refrigerators
I have a 39 ford 6 volt battery operated car. I
you need a voltage doubler circuit which feeds from your 6V DC system and converts it to AC and steps it up and converts it to 12V DC. This device might be difficult to find. OR use a 6Vdc power inverter and just use a 120volt AC fan if much easier to source out in your area.
You might want to try a 12VDC high speed fan and see if the 50% reduced speed is already sufficient for you.
Aug 30, 2009 | 2001 Ford Escape
Engine runs but no AC or DC output.
  1. Remove the rectangular snap-fit cover from end bell
  2. Start generator making sure it's at rated RPM
  3. Using volt meter test brush terminals.
  4. Use red+ lead on top or right brush black is - negative
  5. should see approx. 75 volts DC
If no voltage, need to flash with 12 volts DC same polarity as above, for 5 seconds
Aug 03, 2009 | Coleman Sport 1850 Generator
MISSPLACED AC POWER SUPLY FOR "MY BOOK" 250 GB USB.
THE ANSWER TO MY QUESTION WAS FOUND OUT BY MYSELF BY VISITING A REPAIR / SERVICE DEPARTMENT AND MAKING ENQUIRIES CONCERNING THE DC OUTPUT OF THE AC ADAPTER ASSOCIATED WITH THE WESTERN DIGITAL, MY BOOK 250GB USB. tHE VOLTAGES ARE THESE. : - AC INPUT = 100 - 240 VOLTS 50/60 HZ
DC OUTPUT = 12 VOLTS ( REGULATED ) 2 - 0 A
CENTER PIN OF 12 VOLT DC INPUT PLUG IS " POSITIVE "
THANK YOU FOR THE SPACE TO ASK MY QUESTION.
Feb 18, 2009 | Western Digital My Book Essential Edition...
Output voltage
Hello rcgibson, output of charger for (if this is correct 'Roadmate 800 GPS unit) AC wall power supply or 12/24 volt DC is 5 volt at 455 milliamp.
Oct 24, 2008 | Magellan Universal Ac Wall Power Supply...
AOpen MA-691 Computer Speakers Logo
297 people viewed this question
Top AOpen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an AOpen Audio Player and Recorder Expert? Answer questions, earn points and help others
