Question about Whirlpool Refrigerators
Water on the fridge shelves - Whirlpool Refrigerators
  • 95 Answers
Make sure all objects are clear of the door, usually moisture happens through an air breach. next, see if the drain line is clogged with debris, clear any obtructions.
Posted on Jul 29, 2008
Freezing milk and water bottles on top shelve
Defective temperature sensor in the fridge section.
Aug 30, 2016 | Frigidaire Refrigerators
Chemical cleaner taste in water and ice from fridge door.
Run it as normal and keep flushing the water through. Place lemon wedges around the inside for the next week. If the problem persists you can buy a proprietory air conditioning system cleaner for cars that disperses inside the unit (make sure no food is left in while using) follow makers instructions. Clean with low pressure hot water spray before using again.
Apr 20, 2012 | Kenmore Refrigerators
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Water leaks inside . top shelves of ref section. Every day I sop up water from top shelves. Drain tube frozen?? How do I fix it?
if unit is a whirlpool, a kit is required to alleviate issue..you can turn fridge off and defrost it for 24 -hrs w/doors open...that should eliminate frozen drain problem
Mar 10, 2010 | Refrigerators
Water dripping onto back of shelves and into drawers and bottom of "designer style" frig
There is a tube at the back of most fridges which routes freezer water to a evaporator tray at the bottom.
Usually in the fridge at the top just below the freezer is a small collection cup. If that cup or tube is blocked then it will drip water into your fridge.
Let me know if that helps.
Dec 06, 2009 | Whirlpool Refrigerators
WATER DROPS AT TOP OF FRIDGE
sounds like the door was left open,make sure nothing is overhanging on the shelves preventing the door from closing next time send model number
Nov 27, 2009 | Refrigerators
Water in Fridge
you will need to reset it unplug it for 2hours and try again.
Jul 07, 2009 | Refrigerators
Hi i have a fridge freezer which is a samsung sl39wj1/ xeu and i need help coz it keeps coming up with f5
water in fridge on shelve from freezer.( I am assuming) Have defrosted and cleaned fridge and freezer removed all visable ice and water. Took off vent in fridge no ice. what else can I check out before calling repair man?
Dec 31, 2008 | Refrigerators
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
