Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Dishwasher The panel starts to smoke when i close the door.
  • 868 Answers
This is a very serious problem.Disconnect power and do not attempt to do the repair .Only a qualified servicer should handle this.I'm available if your in California,91791.
Posted on Aug 25, 2008
Why is the dishwasher smelling like electric burning and smoke coming out of the door vent?
Hi friend, thank you for your post!
I understand that your Frigidaire dishwasher is giving off an electric burning smell and you are seeing smoke coming out of the door vent. It could possibly be an issue with your control panel or door vent, both have electrical components inside of them. Since it could be either one of these underlying issues I would recommend having a technician come out to your home and diagnose and repair the dishwasher. Hope this helps. -Matt
Jul 27, 2014 | Frigidaire Dishwashers
Amana dishwaser adb1100aww won't start is there a fuse in dishwasher
If you are able to set the wash program on the panel but the start does not produce any action, then the door latch is causing a problem. There is a switch behind the latch that detects if door is shut. If this switch is not closing then dishwasher will not start.
Check items 4, 6 and 9 in this diagram. Make sure the mains power is disconnected as high voltages come to the door panel.
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dishwasher-Parts/Model-ADB1100AWW0/1268/0130000/W1302287/00002?blt=06&prst=&shdMod=
Apr 19, 2014 | Dishwashers
I start the dishwasher and it does nothing and lights do not turn on either
When your dishwasher won't start, it could be a problem with your electrical panel or the door might not be closing properly.
Check your household electrical panel for a tripped breaker or blown fuse. Also check to make sure the door latches closed properly.
For additional troubleshooting steps you can take and things you can do, read Dishwasher won't start for more suggestions. I hope this helps!
Aug 02, 2012 | Kenmore Dishwashers
Model KUDS01IJBL0 will not start. Keeps reverting back to 2 minute drain when Cancel button is pressed. After the 2 minute drain, I press "Normal" button, or any of the other start buttons with...
If your dishwasher won't start the problem could be the door latch or door latch switches. The door latch assembly is used to hold the door closed during the cycle to prevent water from leaking and it also incorporates the door latch switches that supply power to the dishwasher controls. If the door cannot close properly to activate the door latch switches or if the switches are defective then the dishwasher controls will not receive power and the dishwasher will not start. Inspect the latch assembly including the switches.
The door latch assembly is typically located at the top of the door, behind the inner door panel. To gain access you will have to remove the screws that secure the inner door panel and then separate the inner and outer door. The door latch assembly will normally have two switches that are wired in series as a safety feature. Verify that the door catch will activate the switches by manually inserting the catch into the latch assembly. If both switches are being mechanically activated then you should next check the switches for continuity with a multi-meter. Remove power from the appliance before attempting this repair.
You can learn more on our recent post about the dishwasher 5 simple mistakes you make while using dishwasher Kitchenutilitypro
Sep 26, 2017 | KitchenAid Dishwashers
My dishwasher will not start. I can chose my settings close the door and press start but it will not start.
You have a bad control panel. Here is your part#99003139
  1. Unplug your dishwasher
  2. Unscrew the the screws that run along side the inner door *don't let door drop*
  3. Unplug the ribbon cable and replace the control panel
This would only take 20min to change. Have a great day!
Dec 08, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
My new bosch axxis washer was20160uc does not start
Open the dishwasher door if the desired cycle does not perform as selected on the control panel. Press the main power switch "Off" and then "On" again. Select a cycle, press the appropriate button, press "Start" and close the door. Make sure the door is closed completely.
Check the circuit breaker and water supply if the dishwasher does not start after selecting the appropriate cycle on the control panel and shutting the door.
Turn "Off" the dishwasher and disconnect the dishwasher from the power supply if an error code between "E01" and "E30" appears on the digital display. Reconnect and turn the dishwasher "On." This should reset the control panel.
Terminate a program on the control panel by holding the "A" button and pressing "Start" at the same time. The display will read "0:01". Close the door to start the program sequence. The display will read "0:00" when finished.
Oct 15, 2010 | Dishwashers
Control panel inoperable - 2nd time this has happened. First time repairman said "it was fried" because the panel is just under the countertop - of course this is how it is designed to be. Now it has...
Is it operable when the door is close? I'm having a similar problem. The console panel on the top of the door appears to be not working. No lights. No buttons will respond. However when the door is shut, I can squeeze a finger to the start button and actually start the dishwasher. Light also come on when the dishwasher door is closed.
Aug 11, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
Machine not starting , door not closing well, no click from locking mechanism
The door latch and or door handle assembly which also holds the door switch may have brocken.
If the door latch does not shut properly, this will not close your door micro switch. And if the switch is not closed then the machine will not operate.
Turn off machine at the power source. Open the dishwasher door. You may want to put some weight on the door to stop it from springing back up.
If you have a star allen key or a star shaped tool, you can open the screws around the stainless steel plate of the dishwasher door. Start with the ones on top, which secure the control panel and door lock. See if you can remove the control panel gently without having to open the screws for the front door panel. Sometimes you may need to loosen the front panel screws to free the top control panel.
Once you remove the panel, you will notice a door handle assembly which also holds the micor switch. Take note of how it is set up. Also examie to see if any plastic parts are broken. You may need to order the complete door latch or door handle assembly and replace.
While doing this make sure the machine is turned off at the power source.
Good luck.
Ash
Nov 17, 2009 | Asko 24 in. D3121XL Free-standing...
GE dishwasher GLD5800L Experiencing panel issues - the start or delay button does not work.
The door closed switches on this model are a problem. There are two switches activated by the plunger. They both need to be open when the door is open and both closed when the door is closed. Remove power before working on the switches. I had to add small spacers to adjust the switches position. The touch panel will not work right if the switches are acting up.
Jun 28, 2009 | GE GLD5800L Dishwasher
Dishwasher will not turn on/ start cycle
i would ck incoming power at hook-up behind the lower access panel. maybe a wire nut loosed, if power present there next i would check the door latch switches, if they are not making contact with striker, or switch has gone bad, the machine is not recognizing the door closed and will not operate
Mar 09, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
124 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
