Question about Kenmore 24 in. 16269 Built-in Dishwasher
Soap cup This unit is 30 months old. It does not dissolve the soap tablets and when you open the door after cycle is complete there is condensation on the door. We always use the Smart setting.
  • Kenmore Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
p
Posted on Sep 30, 2010
Soap leaves behind after wash cycle
Could be using too much soap, soap that's too old will clump and not dissolve completely. If your soap is clumpy and very dry, dissolve it completely with boiling water in a pan, then put it in the unit.
Jun 15, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Soap is not dispensing. Sometimes the soap dispensing door isn't opening and other times it is but the soap is not dissolved
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 13, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Soap box not opening and soap not being used during wash cycle even thought the soap button selected.
The soap door is opened by heating a bimetal bar that bends when electricity is applied. This prevents the door from opening when the cycle is momentarily selected preventing the soap from dumping. The unit is behind the soap cup in the door.
May 27, 2011 | Whirlpool Dishwashers
Fairly new dishwasher - a few months old - suddenly this week tablet dispenser doesn't open during wash cycle
heatman101
Mar 21, 2011 | Dishwashers
Soap tablet not being used,not washing dishes
I will assume a few things as you do not indicate which unit you have.
You have a soap dish with a door that should open at the correct point in the cycle. That is probably not happening. You can tell for sure if the soap dish door is still closed at the end of the cycle.
If the door is still shut then something could be jamming it or it is faulty.
Take a look at the dish door and look for soap residue and dirt etc collected around the hinges and the clip holding the door shut. Clean it out.
Open and close the door by hand a few times to ensure it operates freely.
No Go ?
The timer tells the door when to open and close. If the door is faulty or the timer is not sending the signal then the soap will not dispense.
To test the soap disperser you would open the door and move the timer to the position where the soap should be dispensed. Then put a test light across the terminals on the dispenser to see if it is getting a signal. If there is power then the disperser is faulty. It now power the timer is faulty. You would replace the part accordingly.
It is hard to explain in detail how to do the test as I don't know the exact unit.
Short term solution until you get it properly fixed is to use the puck or dissolving package type cleaner. Just put it in the bottom of the machine at the start or open the door mid cycle (unit stops when you open the door) and toss it in. It will work for now.
Hope this helps you with some direction. Please rate this answer if it helps you get started.
Mar 19, 2010 | Whirlpool 24 in. ADG7540 Built-in...
GLD6500 Series Dishwasher -- soap dispenser has
Yes that's normal for that machine. The soap has to be washed out of the soap drawer by the top spray arm turning, and that's usually the problem - the arm isn't turning. Check both spray arms for blocked jets at the very end - remove blockages with a pin and water flow from tap. In the worst case, you may need a new spray arm - but they are usually cheap.
More points to remember - on a rapid 30 minute wash program only, if you are using wash tablets, don't put them in the soap drawer as there wont be enough time for them to dissolve. put the tabs in the cutlery basket. Also - a dishwasher is not a garbage disposal unit, and uneaten food must be scraped of plates before putting them in the dishwasher. Run a dishwasher cleaner through now and then, or do a full program wash with nothing in the machine to clean it out and to keep spray arms clear.
Feb 02, 2018 | GE 24 in. GLD6500L Built-in Dishwasher
Dishwasher only a couple of months old. Ran it
The water may not be hot enough. Increase the temperature of the incoming hot water or try this: put the tab in the open soap cup so it will start to dissolve during the pre-wash. Then it will finish dissolving during the main wash. If the dishes get clean using this method you may not have to increase the water temp.
Aug 25, 2009 | Dishwashers
My soap won't dissolve during the cycle.
You are not getting enough water or you are losing the water during wash cycle. Is you dishwasher new or older? How is it plumbed in? If it is plumbed through the floor you will have to put and air gap in to keep the water in it. All tall tub dishwasher have to be plumbed properly.
Jan 05, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Nov 23, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Soap remains in soap cup after complete cycle is run
I had the same problem. The door on the cup does not open all the way. Here is what I did. On the back of the dishwasher door are 7 phillip head screws. Take those out and the door inner cover comes off. There are 2 pieces of black insulation that are glued to the cover. The smaller one had slid down to where it was blocking the cup door from opening all the way. Pull this black insulation off and put it back in the right place. I even put a little hot glue under to keep it from sliding again. Hope this works.
Nov 18, 2007 | GE Tritonr XL GSD6260JCC Dishwasher
Kenmore 24 in. 16269 Built-in Dishwasher Logo
55 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
