Contributor
- Posted on Feb 28, 2011
Re: How Do I Replace The Heater Core In My 1999 Daewoo...
Removal Procedure Disconnect the negative battery cable.
- Remove the instrument panel from the vehicle.
- Remove the heater/air distributor case from the vehicle.
- Disconnect the vacuum actuators from the vent-floor door and the defroster door.
- Remove the vacuum actuators from the heater/air distributor case.
- Remove the screws that secure the heater core cover to the heater/air distributor case assembly.
- Slowly separate the lower heater core cover from the rest of the assembly.
Remove the screw and the bracket clamp that secure the heater core lines to the case.
- Remove the spring clamp that secures the heater core body to the case.
- Remove the heater core from the case.
