Convergence is out of alignment unable toadjust in. pict and audio finally ceased to work. no hi voltage
  • 8,617 Answers
Your convergence ICs have shut your set down. Please respond to this same post with your model number and I will post the correct ICs for your set and post a link where you can get replacements with free instalation instructions.
Posted on Jul 29, 2008
An older tube model - audio okay, no video - only a narrow line across the middle horizontally
Sad to say this is likely the death of it.
Technically, the time base line output has ceased to function.
Unless you feel it's a full blown crusade to have a vintage working TV you're going to have a hell voyage (unless you're extemely lucky) of cost in time and money to get that put right which you may decide aint' a road worth going down.
Better to put your money into a new flat screen TV but if you've the storage space don't scrap the old TV. Depending on it's present age it will be worth something soon to a collector or theatre/TV/movies props hire supplier.
Sep 20, 2011 | Panasonic Televison & Video
The guns are out of alignment so its showing in shadows, so how do i get them back align?
The first step would be to use the original remote to fix the convergence problem. You need to go to menu > convergence and then try to align the convergence.If you are unable to fix the convergence by remote, you need to open the TV and replace convergence IC's. This is a simple fix.
If you have an electronics repair experience and would like to repair the TV yourself, revert and i would guide you how to replace the convergence chip on this set.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 12, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Sony color rear video projection, Sn 9720391, model KP65WS510. Looks like 3D without glasses. Red double words and pict are shadowy
Common problems with rear screen projections. Either you need to refocus the alignment, or you need to have the Convergence IC's replaced. In your owners manual, it should tell you how to refocus the alignment.
Feb 15, 2010 | Toshiba 53H71 53 in. Rear Projection...
Unable to enter convergence menu
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 08, 2009 | Toshiba 42H82 42" Rear Projection...
Panasonic PT47WX54J is showing a red shadow behind words and pict
you need to go to your remote, look up menu. then select "convergence"...this will give you a "crosshairs pattern to align your "guns" ...it has three red, blue, and green.....try not to move the TV around too much....its knocking them out of alignment
Oct 01, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Auto convergence no longer works on Mistubishi WS-55807
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Jun 12, 2009 | Mitsubishi WS-55807 TV
Red and green double vision
This is a convergence problem that is either poor solder connections on the convergence ICs or defective ICs. If you can solder and are comfortable working inside the set where there are ptentially dangerous high voltages present even when unplugged, you can fix this yourself.
Please let me know if you wish to attempt the repair and I'll supply additional details and instructions.
Dan
Mar 19, 2009 | Sony KP-EF41 41" Rear Projection...
Can't set red convergence on 65" Hitachi
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Dec 24, 2008 | Hitachi Director's Series 65XWX20B 65"...
Distorted pict. w/ wavy circles
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 01, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Convergence
If a convergence issue exists, alignment is secondary to the
repair.....you did not indicate if you already repaired problem
and are now doing final re-alignment.....T.
Usually, two STK IC's are replaced............................
Dec 16, 2007 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
