Question about KitchenAid KGST307 Gas Kitchen Range
The right side 2 burners ignite by itself
My right side 2 burners ignite by themself as soon as I plug in power outlet. They just keep igniting and I can turn 4 burners on without problem. The problem even flame is on, the ignitor just keep popping.
Any suggestion is welcome.
Thanks
mchael
  • hmh166 Nov 03, 2008
    I am having the same problem. All of a sudden the burners just pop for no reason, I have to unplug the stove to get it to stop
    Sergeant:
  • 409 Answers
Sounds like the spark module is trying to light the elements. have a technician come out and take a look at it.
Posted on Sep 13, 2008
Lofra service perth
Instructions
    • 1 Disconnect the range's power supply, either by turning off the breaker in your service panel, or unplugging the range from the wall outlet.
    • 2 Remove the burner grates, burner caps and burner bases. On some ranges, the burner bases are secured using screws, which you must remove.
    • 3 Insert a putty knifeicon1.png into the gap below the front of the each side of the range to release the spring clips securing the top to the range.
    • 4 Lift the top, and then have a partner hold the top up. If you are repairing the range alone, place a sturdy object under the top to secure it.
    • 5 Remove the burner orifice containing the igniter that you are replacing.
    • 6 Remove the screw securing the igniter to the underside of the orifice, and then remove the igniter.
    • 7 Pull the igniter wire off of the terminal, and then discard the igniter.
    • 8 Connect the igniter wire to the new igniter.
    • 9 Secure the new igniter to the underside of the orifice using the screw that you removed.
    • 10 Replace the burner orifice, and then secure it into position using the bolt that you removed.
    • 11 Lower the top onto the stoveicon1.png, and then press down to engage the spring clips.
    • 12 Replace the burner bases, caps and grates.
    • 13 Restore power to the range by plugging it back into the wall outlet or turning on the range breaker.
Read more: http://www.ehow.com/how_12064545_fix-ignition-switch-stove-top.html#ixzz2bSNNTBF9
Aug 09, 2013 | Kitchen Ranges
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
All 4 Igniters keep firing after the burner is lit.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
ghhdf
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Only the two left spark ignitors work. I switch the wires from the left side to the right side and the ignitors worked. The wires from the right side I hooked to the left side and they did not work....
Dec 09, 2009 | Hotpoint RGB745 Gas Kitchen Range
Igniter keeps clicking ...gas all burners light, but clicking continues
Oct 06, 2009 | Tappan TGF320 Gas Kitchen Range
I need the diagram to put the spark plug cables
2003 Chevrolet Malibu 3.1L SFI OHV 6cyl
Spark Plug Wires - Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
    NOTE Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  2. Remove the intake manifold cover, if required.
  3. Disconnect the left side spark plug wires from the spark plugs.
  4. Disconnect the left side spark plug wires from the ignition coil.
  5. Remove the spark plug wire clips from the Manifold Absolute Pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
  6. Remove the spark plug wire assembly.
  7. If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
  8. Disconnect the right side spark plug wires from the spark plugs.
  9. Disconnect the right side spark plugs from the ignition coils.
  10. Remove the spark plug wire assembly.
  11. If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
To install:
  1. Install the spark plug wire assembly.
  2. Connect the right side spark plugs to the ignition coils.
  3. Connect the right side spark plug wires to the spark plugs.
  4. If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
  5. Install the spark plug wire assembly.
  6. Connect the left side spark plug wires to the spark plugs.
  7. Connect the left side spark plug wires to the ignition coil.
  8. Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
  9. If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
  10. Install the intake manifold cover, if required.
Fig. 2.2L Engine Firing Order: 1-3-4-2 Distributorless ignition system
Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.5L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 2.4L Engine Firing order: 1-3-4-2 Distributorless ignition system
Fig. 3.5L & 3.9L Engines Firing order: 1-2-3-4-5-6 Distributorless ignition system
I really hope help you with this (remember rated this help) Good luck.
Sep 23, 2009 | 2003 Chevrolet Malibu
2 of 4 burners ignite, all tick?
The two front burners are used most often. On the side of the burners are tiny holes that become plugged and keep the burner from lighting. If all the burners are the same size try swapping the heads around. If they are not all the same size be sure they are in the correct position and fully seated on the top. Sometimes the heads have to be replaced when cleaning no longer works.
Jun 08, 2009 | Kitchen Ranges
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Oct 12, 2008 | Jenn-Air 30 in. JGD8430A Gas Cooktop
KitchenAid KGST307 Gas Kitchen Range Logo
104 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
