You need to finish the flag clear.
Turn key to PROGRAM mode.
Turn power off at wall.
Hold RECEIPT FEED down - keep your finger on it.
Turn power on at wall.
Wait 5 seconds, then let go of RECEIPT FEED.
You should see "FFFFFFFFFF" on display.
Press SUBTOTAL.
Wait for print out.
Turn back to REG mode (you may need to sign back on)
may i know why i try but it dosen't work.. can you help me?? thank you so much
thank you very mutch !! you are more practical then casio assistance ;)
can someone help me plzz
I have the same problem and neither of these solutions work. I've done them many times. I never get the FFFFFFFFF code and i never get any print out. After doing them, when i turn the register on i just get
INIT
0000000000
and pressing any button except the number buttons generates the E004 Error INIT/FC. Any other things i could try?
That just means your machine isn't waiting for a flag clear to finish. It simply has no programming at all. If it is a new machine, this is normal and it will need a MAC (init) code which you get from the programming manual. If it has been programmed before, it has a flat or faulty battery and this should be changed first or it will keep losing the code and all programming.
Apakah saya bisa menghubungi anda lewat telepon agar lebih jelas, karena saya sudah melakukanya cara2 itu, akan tetapi masih belum bisa.
to restore the casio te2200 to factory condition turn the key to program while holding down journal feed. when all 0's appear in display enter 22500 then hit subtotal twice. If the machine is a te2400 use the code 20400 instead. If you want to use clerk secret numbers use 22510 or 20410 respectively.
Solved my issue Thanks a lot
Sign on
Turn power off at wall. Turn the key to the OFF mode and Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then turn the key to PGM Mode then wait for five seconds, let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL. Wait for print out. Turn back to REG mode (you may need to sign back on)
SOURCE: plz solve my problem casio
If the register is new, this is normal, it just needs programming.
Otherwise, it may have had a lock up.
Try this:
Hold RECEIPT FEED down (may just be called FEED) - keep your finger on it.
Press SUBTOTAL.
Wait for print out.
Turn key back to REG mode and try it.
If anyone needs more information, the Casio SE-S300 manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_users_and_programming_manual.html
did this now only got - - - - on top line any idears
after the row of dashes appears enter the secret program code: 11 cash 22 subtotal 33 chk 11 cash 22 sub total 33 chk
hellooo
