Sacale la bateria y desconecta la electricidad. Presiona el boton de ON por diez segundos luego conecta la electricidad y prendela. Si no funciona el Mother Board se da?o.
To remove the chips, gently heat the exposed legs of the IC with a soldering iron and desoldering wick. When you have removed most of the solder, you will be able to pop the chips off the board. To apply the new chips, see this video on Youtube https://www.youtube.com/watch?v=QiIy3Oe2UGI
there are a few things that could cause this but here are the first two to look into before the last and worse case
your power adapter may have died. you need to have it checked. if it is ok then you porbably damaged the jack. if the jack is ok well then your motherboard has an issue. either the board is damaged or another problem exists.
Try removing the battery, it may be defective. Remove the battery and see if the unit powers up when plugged in. Check to see if the charge light at least comes on when it's plugged in....if it doesn't, then the socket the power supply plugs into may need to be re-soldered.
Hi there,According to the Acer Manual for your Laptop,The Fn+F3 keys Enable/Disable bluetooth.You can find out more about your laptops capabilities here...
It may be wiring problems in the articulation area of the camera. This was my problem and others had same problem. Try moving the camera to a different position a little at a time and then try connecting again. I tried downloading drivers, etc. not the problems with mine.
-Go to Windows Start -Type in "Launch Manager" -Choose whatever program you want to customize button to. -If your program isn't listed there select "Add" -You can add whatever program from your computer of type in a web address from there. P.S. Acer doesn't list this anywhere, and they want to charge you for the info if you call them (so wrong of them).
