Question about Maytag MDG7657BW Gas Dryer
Stops heating shortly after starting the cycle.....
.....I have cleaned out the excess lint in the dryer and the vent tube. It did not seem like an excessive amount. Also tried running a cycle with the vent tube removed. This did not help.
  • juicd302 Jul 29, 2008
    Paid $9.99 to be directed to another site?
    The solutions offered by repairclinic.com doesn't seem to fit my problem. My dryer will heat initially then stop heating shortly after starting. Since the gas lights, It's not the igniter. Gas lights,so not the gas valve coils. Site says if the Thermal fuse is blown the dryer will either not light or not work at all. So what next?
    Guru:
  • 1,894 Answers
Ifyour dryer is not getting any heat, you need to make sure there isnothing blocking the front of the dryer. Air flow is key to efficientdrying. Make sure the dryer settings are appropriate for the clothesyou want to dry. The timer selection, fabric selection, and thetemperature selection all play important roles in proper dryeroperation. Check the heating element, burner operation, igniter, thermalfuse, and the wiring (power cord).
Visually inspect your heating elementfor any broken or burned areas. The heating element is a coil made froma nickel-chrome alloy, called nichrome. Check the coil for continuitywith a Volt Ohm Meter. If there's no continuity, it means that theelement is bad and you need to replace it. An electric dryer shouldhave it's own separate power line.
When theburner is operating properly, the flame should beclean and blue.
If the igniter is cyclingwithout the burner lighting, you probably have defective electricalcoils in the gas valve. These coils look like black cylinders withwires coming out the top of them, and are located near the burner valveassembly. When they get power, they open up and allow the gas to getthrough to the burner. If this is a new installation, make sure the gasvalve is turned on.
If the ignitor doesn't glow, look for a white or yellowishdiscoloration, or for a break in the ignitor. If this is somethingvisible, just replace the ignitor. If there are no obvious signs of abreak or burnt area, test it for continuity. If the ignitor doesn'thave this type of problem, you'll need to determine if the problem isin the control area, or somewhere else within the burner system. Testfor 110v getting to your burner assembly.
Here's a test you can perform: Unplug your dryer and then openupthe burner inspection panel. Unplugging your burner assembly unit, youwant to connect your jumpers for the Volt Ohm Meter to the dryer sideof the assembly, not the burner side. Keeping your Ohm meter wires awayfrom the drum area, set the timer to on, set the controls to high heat,and then plug the dryer back in. If there is 110v in this area, you canassume the thermostats in this area are good. If not, a timer, motorcentrifugal switch, or other thermostat may be your culprit.
To protect from over-heating, many dryers use what's commonly called a thermal fuse.If the thermal fuse gets too hot, it will blow, and completely shutdown your dryer until it is replaced. This fuse is often mounted withinthe exhaust duct in the back panel. It's about an inch long, and isusually found within a white plastic housing. When fuses blow, it meansthey have no continuity and no power will flow through it. A badthermal fuse needs to be replaced. When replacing this fuse, check thedryer vents to make sure there is no lint buildup which can cause theheat to stay trapped and blow the fuse again.
[Back]
You should visually inspect the wiringconnections to the dryer from the house regularly. If you're openingthe dryer case, give the wiring inside a good visual check as well.Lastly, never use an extension cord to operate this appliance. Anelectric dryer draws a lot of power, and the shorter the wiring to it,the better. The power cord connects to a terminal block in the back ofan electric dryer. Sometimes this terminal can get burned out or groundto the dryer. Make sure the power is turned off, and look forscorching, burned, or broken connections. For electric dryers, onebroken connection might allow the dryer drum and timer to operate, butthere would be no heat.
Posted on Jul 29, 2008
  • 13,433 Answers
Heat problem
Sound like thermostat is not working. Should turn off heating elements when drying temp. is reached.
Jan 20, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
We have a combo dryer and washer. Washer is A2444330KH. Leaves lint on cotton shirts, have cleaned the filter no help. Any ideas? David
Dryer lint not only presents a problem by cluttering up your clothes with white specks, but it can also lead to a dryer fire. While it is impossible to completely eliminate dryer lint, you can take action to drastically reduce lint and the potential problems that come along with excess dryer lint. If your clothes take more than one cycle to dry, you see no lint on the lint screen, the clothes are very hot after drying or you find excess lint on the clothes after drying, you probably have a problem with accumulation of dryer lint in the dryer vent.
Use a dryer vent cleaning brush and clean the dryer vent, or hire a professional to clean the exhaust vent behind your dryer. If your dryer vent is clogged, it will create excess dust in the dryer and on the clothes. The excess lint can eventually catch on fire given the heat load of the dryer.
Dec 05, 2010 | Maytag Washing Machines
About 12 to 20 minutes into the drying cycle, the dryer stops and all of the led lights start flashing (drying, cool down, press saver, clean lint filter". Also, the dryer doesn't seem to get warm,...
sounds like a restriction in the venting process, i would first disconnect the vent tube and run the dryer, if that clears the problem then I would clean out the vent tube. If not then I would take apart dryer and clean out all of the lint. Hope this helps Tim
Nov 26, 2010 | Dryers
The dryer runs but there is no heat ,igniter glows, but i do not know if it is on long enough or if it get hot enough.
This is usually a symptom of a lint clogged vent or restricted air flow through an expandable, plastic or foil vent tube behind the dryer that is squished. First check your lint filter and clean it. With the filter removed, check the filter reservoir and see if there is a lot of lint that needs to be cleaned out. If not, then you will more than likely need to pull the dryer out to check the vent for blockage. Unplug the dryer and remove the vent from the back of the dryer. Using a flashlight, clean out or vacuum2_bing.gif out the excess lint. Do the same for the vent tube you disconnected. Also check outside at the vent cap to make sure it is not blocked there and that good air flow allows the vent flap to open when the dryer is running. You can check this after you reassemble the vent inside and fire it off. Hope this helps solve your problem. Douglas
Jun 03, 2010 | Dryers
Turn dryer on and it starts to heat up and then the heat stops and within about 2-3 minutes will start to heat up and then the heating up stops.
Clean out the exhaust vent tubing really good.. A moister sensor will detect any build up of lint and shut the heat off
I have a kenmore 76712. clothes only gets warm but does not dry even after 3 cycles. I have looked in the back cabinet and i see the ignition working and lighting up. But it goes off after about 5-8 secs...
The unit must be taken apart to clean. Also the duct work (vent tube) will have to come completely apart for those tubes will be solid full of lint as well. That is why the dryer is not drying your clothes. I guarantee you will find a handfull of lint for every foot of tubing you have. OInce cleaned the dryer will operate like new again
Apr 21, 2010 | Dryers
Our Amana Dryer is not drying clothes properly. It does not seem to heat up properly and takes quite a long time to dry a load. The air flow seems to be good. There is not build up of lint in the hose and...
Hello there:
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
- If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 110 degrees and 150 degrees. Check that the drum seals are not worn out.
Dec 23, 2009 | Amana Dryers
Whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Mar 03, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
DRYER SHUTS OFF ON HIGH SETTING- FINE ON LOW HEAT
lets start simple on this,first check your dryer vent for obstructions(mainly lint build up,)also check the weather flap (where your unit vents to the outside)this should swing open when the unit is in operation.either one of these can cause excessive heat build up in the unit.(this will cause the thermal limit switch to shut the unit down)thus keeping you from setting your clothes on fire.hope this helps,thanx for using fix-ya
Nov 25, 2008 | Dryers
Maytag MDG7657BW Gas Dryer Logo
110 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
