Question about Panasonic Microwave Ovens
I have a Panasonic NN-S961 microwave. It turns on when I open the door. When the door is closed it turns off. Otherwise it opperates normally.
  • Panasonic Master
  • 9,086 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
NN-T994SFR. Inclosed light stays on and the indicator states the door is open.
It is micro switch when you close the door, the door latch push in a button on the micro switch take lid off open and close the door and see if you can spot a button not popping out properly or the latch not in line with the switch
Oct 04, 2013 | Panasonic NN-T994SF Microwave Oven
What is the dimension of the rotating plate I broke mine
Here is a link to the replacement glass cook tray for your Panasonic NN-S961 microwave:
http://microwaveglasstrays.com/shop/panasonic-microwave-glass-turntable-plate-tray-f06014m00ap-p-156.html
And here is another link to that part from Sears Parts Direct:
http://www.searspartsdirect.com/partsdirect/part-number/Panasonic-Parts/Microwave-Parts/F06014M00AP/0022/568/Model-NNS961/0789/0123245?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=50019470&diagramPageId=00001&productTypeId=x&searchModelNumber=NNS961&subCompDesc=Cabinet%20parts&brandDesc=PANASONIC&modelDesc=MICROWAVE&blt=11
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
As you can see from the website, the tray has the following dimensions:
Glass tray measures approximately 16 1/2 inches in overall diameter.
Outside diameter of turntable track is 10 7/8 inches.
I hope that was helpful to you, good luck and take care.
Joe.
Sep 06, 2011 | Panasonic NN-S961 Microwave Oven
Our Panasonic NN-S763BF microwave turns on (light goes on, table turns and fan goes on) automatically when we open the door even though the clock is displayed. It works normally when the door is shut....
You have a faulty interlock switch (which the door operates).
This needs to be renewed by a qualified microwave service technician ASAP.
A potential hazard if not fixed immediately!
Oct 06, 2017 | Panasonic NN-S763BF Microwave Oven
NN-A574SBBPQ - Microwave fans & turntable not working
2 fuses in a panasonic does not sound enough.
have you checked the main incoming power protection fuse normally 10amp or higher.
most panasonics have approx 4 fuses so keep on looking
Feb 10, 2009 | Panasonic NN-S961 Microwave Oven
Microwave stops after 14 seconds.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 22, 2008 | Panasonic NN-S961 Microwave Oven
Door shut off malfunction
I have the same problem starting yesterday April 19. Have you gotten any answers.
Mar 12, 2008 | Panasonic NN-T993SF Microwave Oven
Panasonic Microwave Turn table rotates when door is open
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
Nov 03, 2007 | Samsung SMH7159 Microwave Oven
Microwave NN V622m locked
To lock, press START 3 times. To unlock, press STOP/RESET 3 times. If this doesn't work, contact Panasonic Support at http://www.panasonic.com/support/
Mar 26, 2007 | Panasonic NN-V671S Convection Microwave...
Microwave Ovens Logo
63 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
