Question about Samsung DLP HL-P5663W 56" TV
White lines on Samsung DLP
You posted "do they look like jail bars ,running from top to bottom." regarding a problem of having vertical white lines. Do you know what this is or how to fix it? I have a Samsung DLP about 3 yrs old. Thanks
  • romanw Jul 30, 2008
    Its a Samsung hlp5063wx. From what I gather it needs a new DMD board but I would like to have more input before ordering this expensive part. I know there is no way to be 100% sure but I would love to know if you think that is the problem.
  • romanw Aug 01, 2008
    Wow I can't believe a three year old television needs a $500 part already. I am sure it will need a new lamp soon also. Now, you can get a new television for just over $1000 so it doesn't make sense to keep buying parts. Too bad they don't tell you to expect only a few years of use from these televisions. :(
    Champion:
  • 317 Answers
Or optical eng.
Posted on Aug 03, 2008
    Sergeant:
    Champion:
  • 375 Answers
Need the modle number to see if there is a service flash or fix/
Posted on Jul 30, 2008
  • g w Jul 30, 2008
    there is a service tip on your systom /replace the dmd board assy. part #bp96-00678a you might want to price the part first,quite pricy/ technical support for samsung is 1-800-313-8513
Samsung HLR DLP TV with white lines from top to bottom. First had no picture, bulb is 10 months new, I replaced the color wheel, and just put in a used DLP Chip. Picture came back perfect, but these w
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 18, 2017 | Samsung Televison & Video
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
White vertical lines like jail bars
Jun 26, 2017 | Samsung HLN5065W 50" Rear Projection...
Vertical white lines appear on the screen. Samsung provides the following information but doesn't say what circuitry they are referring to. Samsung says: DLP TV: I Have Vertical White Lines...
That answer I agree makes no sense.
Most of these sets have NO vertical hold and if did it will not cause the lines.
A brief educated guess:
Set has a main board that communicates and controls the screen--tests for that are not simple (checking waveforms with a scope and signal generator).
The model indicated here is a DLP that uses a lamp (let me know if model listed is not the one you have).
In DLP sets aside from main/digital board you also have a optical light engine---it processes all signal in and out to the screen.
Optical engines do fail and cause some simple and some complicated picture issues.
Some will even cause the set to "lock up" with a picture or strange looking screen---clue to this is you have to shut the set off by pulling the power cord.
The set may be old enough they do not really want to help you or even talk about it.
May 22, 2012 | Samsung HL-S6187W 61 in. HDTV
My tv have vertcal lines wend I just tern on but wend heat up dosent do any more ?? Samsung HL-R5656W 56 in. HDTV DLP TV
You are probably seeing what looks like Jail Bars (Vertical Lines evenly spaced) on the screen. If so,then the DMD chip on the DMD board is bad and needs to be replaced
Apr 03, 2010 | Samsung HL-R5656W 56" DLP HDTV
After changing color wheel on my samsung hlr 5067w tv my picture is high with black bar on bottom.top of heads are cut off.what went wrong? no proble before.
Hi,If you are experimenting vertical lines ,black bars ,color
distortion,pixilation,or white dots on the screen you might be having an
issue with the Dmd chip.This is how the DMD chip works:
http://electronics.howstuffworks.com/dlp1.htm Basically the dmd chip
is composed of around 2 million pixels that create the image on the
screen.You will need to replace in order to fix your problem.Have a
blessed one!
Feb 09, 2010 | Samsung HLR5064W DLP Projection TV
VERTICAL WHITE LINES
I just read a post that said tap on the top and the line will go away. I tried it on mine and it worked! I had to tap it fairly hard. I just kept tapping harder and harder on the plastic in front of the buttons and voila! The vertical white line disappeared!
Oct 07, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Dlp white vertical lines
YOU NEED CHECK THE 3 CRYSTALS ( RED, GREEN AND BLUE). CLEAN IT WHIT "DUST REMOVER" ( compressed gas duster) AND REPLACE THE COLOR WHEEL.
Jan 17, 2008 | Televison & Video
Problem with the White vertical lines on Samsung 50 in DLP
Get DMD board part # and shop for best price.......
I will do the same......let me know.....T.
Nov 05, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung dlp
Aug 30, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
506 people viewed this question
Henry  Thomas
Henry Thomas
