Question about Insignia Sport MP3 Player
I can't get any program to acknowledge the device is hooked up
I have synced the device only the first time, am new to this, and wanted to change the list and the order, so I erased teh internal memory to start over again. Now I cannot get any program to acknowledge the device. I was using Windows Media Player and have tried Best Buy rhapsody. It will charge, and it asks me when I plug in what I want to use. I now can only use the radio function.
  • lfkeg0 Sep 05, 2008
    my computer says it doesn't recognize my device. tells me to install hardware. I don't have any. Insignia sport mp3
  • freestyle14 Sep 28, 2008
    When i Try and use my media converter, Arcsoft, it simply states "no device attached", but i can see the USBport icon in the bottom of my computer. help me!
  • 27 Answers
Look for the hard ware download for your operating system...XP...MAC...Ect. and go to device manager to see if it was installed
Posted on Oct 30, 2008
Where is the Learn button on the Liftmaster 1/3hp 1145 model garage dr opener? We are trying to sync a new opener.
This model will have a round or square button on the rear of the unit and a small indicator light beside it , The indicator light will blink from time to time so when you see that just look to its left and that's the smart button , if you press the button you will see the indicator light come on , if you were to hold it down for more then 6 seconds you will wipe out all existing codes like from a keypad or remote control ! You would hold it down in the event you want to change the code on your remote or keypad ! People normally would do that in the event they just bought the house from a previous owner! If you are programming you would only need to press the smart button one time and then press and hold down the button on your remote you want to program, since its a smart button it realizes that you are now sending the opener a signal and it will automatically lock into your signal to sync up , The key pad is almost the same so you would want to press the smart button once ..then go over to the keypad and put a 4 digit # in and press Enter as a final command , the opener will let you know it has received the signal when the openers light bulb turn on and then off ! This will be the opener acknowledging it has successfully received the code! Hope this was helpful fr you Sincerely Glenn
Feb 15, 2015 | Building Materials
MP4 player
The first time you connect a device that plugs into a universal serial bus (USB) port, Windows automatically installs a driver for that device. After a driver is installed, you can disconnect and reconnect the device without performing any additional steps.
Before you install your device Check the instructions included with the device to determine whether a driver should be installed before you connect the device. Typically, Windows detects a new device after you connect it, and then installs the driver automatically. However, some devices require you to install the driver before plugging the device in.
Also, while most devices that have power switches should be turned on before you connect them, others require that you turn them on during the installation process. Because of issues like this, it's a good idea to read the instructions included with a new device before you connect it.
If the instructions that came with your device contradict the information in this topic, follow the instructions that came with the device.
Plugging your device in If your USB device1.gif uses a power cord, you should connect the device to a power source and turn it on before connecting it.
Next, determine which USB port you want to connect your device to. If your computer has USB ports1.gif on the front, consider using one of those if you plan to frequently connect and disconnect the device.
YOU MUST NOW " SYNC" YOUR DEVICE WITH MEDIA PLAYER THIS IS HOW TO DO IT.
Set up a device to sync in Windows Media Player You can use Windows Media Player to copy music, videos, and pictures from your Player library to a portable device, such as a compatible MP3 player. This process is called synchronization or syncing.
There are two methods for syncing items to a device: automatically or manually. When you connect a device to your computer for the first time, Windows Media Player selects the sync method that works best for your device, depending on the device's storage capacity1.gif and the size of your Player library. After your device is set up the first time, you can choose a different sync method if you want.
  1. Start the Player, turn on your device, and then connect it to your computer. If prompted, select the AutoPlay option to sync the device using Windows Media Player.
  2. Do one of the following:
    • If the Player has selected to sync your device automatically, click Finish. When you do so, the Player will sync your entire library to your device. After that, your device will automatically sync every time you connect it to your computer while Windows Media Player is running.
    • If the Player has selected to sync your device manually, click Finish. Then, in the Sync tab, you can select the files and playlists you want to sync manually. For more information, see Sync manually in Windows Media Player.
Comment by Christalnet, posted on Feb 12, 2008I HOPE THIS IS HELPFUL.... PLEASE CONSIDER USING A LIVE CHAT BOX OR YOU CAN INSTANT MESSAGE ME FOR HELP IN DOING A WALK THROUGH IN REAL TIME, YOU MAY CONTACT ME USING........
MSN MESSENGER- CHRISTALNET@HOTMAIL.COM
YAHOO MESSENGER- CHRISTALNET@YAHOO.COM
OR I USE ICQ # 147169792
Comment by Christalnet, posted on Feb 12, 2008You can find a nice walk through on transfering music manually and installing third party apps for this purpose by clicking HERE
Feb 13, 2008 | Microsoft Windows Vista Ultimate Edition
When I plug my Kobo ereader into my laptop, it is not acknowledged by my Kobo desktop. Also when I try to send a book to my ereader from downloads, there are no options; the port(s) used before now only...
Hi Brian,
Kobo has, unfortunately, had a lot of issues with their hardware. Your best option is to:
  1. Uninstall any software it came with.
  2. Restart your computer.
  3. Reinstall the software your device came with and re-sync.
Alternatively, you can use Windows Restore Point's and go back to a certain point in time where the Kobo device and your PC could sync. The link to do this can be found here:
http://windows.microsoft.com/en-us/windows-vista/system-restore-frequently-asked-questions
If this helps, please rate this thread and/or post any comments/follow-up questions. Thank you and have a great day!
-Alex K.
Nov 03, 2013 | Computers & Internet
Can I sync two different iPods to the same computer
1. The automatic settings in iTunes and iPods will not allow you to sync two iPods with one version of iTunes or sync an iPod with multiple versions of iTunes without the content being completely erased from the iPod. 2. This can be very aggravating if more than one person in your household owns an iPod or you want to add music from a friend's iTunes library to your iPod. Changing the iPod settings through iTunes will let you sync more than one iPod on one computer.
3. Open the iTunes software. Connect one of the two iPods to a USB port found on the one computer. If a small window opens in iTunes after the program recognizes the iPod, you can close the window by clicking "No" or the "X" in the window. 4. Click the name of the iPod positioned under "Devices" on the left side of iTunes. When you highlight the iPod name, a variety of tabs will appear at the top of the iTunes program. 5. Choose the "Summary" tab and options will be listed in the middle of the program. Select the option labeled "Manually manage music and videos." If a window opens, click "OK." 6. Click "Apply" in the bottom right corner to change the settings on the plugged in iPod. Leave iTunes open. Repeat steps 2-6 with the second iPod you want to sync on the one computer.
Apr 09, 2013 | Apple iPod Audio Players & Recorders
Computer won't acknowledge mouse
Turn on bluetooth on the laptop / computer
Put in fresh batteries
Hold down the bottom sync button
Open up bluetooth manager program in computer
CLick on "search for / discover new devices"
Install found mouse device
Jun 21, 2010 | Sony VAIO VGP-BMS33/B
Computer won't acknowledge Mp3; can't sync anymore song
you can try syncing it thru bearshare. try that.
Apr 29, 2009 | Computers & Internet
Trouble with hooking mpc4k and korg triton pro to mbox
you will want your triton midi-in to go to your mpc midi-outB
then your mpc midi-inA to go to your mbox
your mpc midi-outA to go to your mbox
that should get you good for midi cables....
on the mpc, everytime you want to record a track using instruments from your mpc you will need to set a new track. on the main screen you would go to a new track (where Tr:01-Track-01 is) and change S:DRUM1 to S:MIDI, then to the right of that where it says OFF, turn that to 1A-Device01 ... you will have to make a new track for each instrument you use to help when bouncing tracks to mbox. for instance 1A-Device01 is the 1st track on your triton, 2A-Device02 is your second track and so on. make sure you also make a new track each time for where Tr:01-Track-01 is also for each instrument.
for the mbox i might be a little rusty on this so im going to post a quote from another site....
"in Pro Tools, go to setup - midi - midi studio. this is where you tell pro tools where your midi devices are connected. next, go to setup - midi - midi beat clock. you want to 'enable midi beat clock' and select the devices that are going to be receiving midi beat clock. all devices that you setup under midi studio should be showing. next, set pro tools' tempo for the session if you haven't already. This setup is based on Pro Tools being the MASTER device and the other device(s) SLAVE(S). Make sure that on your hardware/midi interface that the midi output is going to the midi input on the slave devices. On the mpc, press mode, then pad 9 and go to the sync tab. Choose "slave" under "sync in" and the port, 1 or 2, that your mpc will receive midi input. That's it!! When you start Pro Tools' sequencer, the mpc should start too at the same bar/beat location. I've tried slaving Pro Tools to the MPC1000 and Fantom Xa on diff. occasions but I could never get them in sync with Pro Tools. Tried diff. framerates and settings, but still, no luck. So I prefer using Pro Tools as the MASTER sending midi beat clock. Another thing, make sure that whatever you're tracking into Pro Tools doesn't change tempo during the song. If so, you'll have to edit tempo events in the tempo ruler. Hope this helps!!"
let me know if you need any more help.
Feb 16, 2009 | Akai MPC-4000 Plus Production Center (w/80...
Microsoft Money etc. Sync Problem with iPAQ hx2495b
IT WAS COZ OF UR WINDOWS SO U SHOUL CHANGE UR WINDOS BECOZ UR DRIVER NOT SUPPORT IN UR VISTA WINDOWS SO CHANGE IT
Dec 02, 2008 | Dell Axim X51v Pocket PC
UR SYSTEM GOT THE VIRUS SO NEWLY INSTALLED UR WINDOWS AND INSTALLED LATEST ANITIVIRUS WITH UPDATE.
Oct 05, 2008 | HP iPAQ HX2490 Pocket PC
Archos 604 (not wifi)
it needs the corect softwear puting on it it cant sync over wise because it cant format the files it is trying to reseve
Oct 18, 2007 | Archos 604 Digital Media Player
Insignia Sport MP3 Player Logo
48 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
