I need a new squirrel cage blower for my 1970's Singer GB-2100 furnace. Where can I go? How do I find a generic one that will "fit" ?
  • nanphil1 Oct 05, 2008
    I need a new squirrel cage,
    it is broken
22yooper
  • 828 Answers
SOURCE: Mod ASU24C1
If the blower is made of plastic it does not have a set screw. You most likely need a new squirrel cage. They are formed to the shaft and have a compression ring that holds them in place.
Posted on May 29, 2008
SOURCE: NEED A SQUIRREL CAGE FOR
Why do you think you need a squirrel cage?
Posted on Jun 20, 2008
  • 14 Answers
SOURCE: Air conditioner/furnace squirrel cage fan remains running when th
probably the fan switch stuck on the fan combination control or improperly adjusted. Turn power off, remove red wire on the relay from the fan motor. Isolate so no short will happen and turn power on.The motor should not run. The fan relay could stick also. You will have to use a volt meter and see if there is voltage on the coil terminals on the fan relay. Put 1 lead to ground and touch only the terminal for the coil on the relay with the other meter lead.It should not have 120volts. If it does it is not the fan relay but possibly a limit sending power to the relay. Try that first thank you J
Posted on Dec 19, 2008
  • 659 Answers
SOURCE: new furnace, goodman and reinstalling squirrel
Follow your schematic on the new unit. It will tell you where the wire goes. Some of the "extra" wires are connected to the main board close to where the "used" wires are and they are labled "spare". Find the blower motor on the schematic and trace out where this wire will go.
Posted on Mar 20, 2009
  • 4 Answers
SOURCE: My squirel cage blower motor fails to start
Sounds like the start winding is shot. If the cap is good as well as the run winding but it will not start on its own, either the start winding or starting switch. In any event the cheaper thing would probably be to replace the motor. You could take the mottor to a motor shop and ask them if a repair would be possible or cheaper.
Posted on Jul 08, 2009
This blower motor lost some blades some how threw it all out of wack (wobbly) so much it hitting casing. Motor works. Would I need to replace everything or just the blade wheel ? It is an older amana air...
you may have to replace the blower because the squirrel cage is out of balance due to the loss of blades.
and may have damaged the bearings/bushings
if you can get just the squirrel cage that great
Sep 13, 2013 | Heating & Cooling
Why is it whining and humming?
Sometimes a louver on the squirrel cage comes loose maybe from taking it apart...hand test every louver. You may find that you need a new one.
Jun 29, 2012 | Emerson Lennox Ducane Armstrong Furnace...
CAN FURNACE BLOWER BE REPAIRED???
sorry but a search for that did not locate anything here in USA
Nov 18, 2017 | York Furnace Draft Inducer Blower Fasco #...
My furnace just started running loud and floor began vibrating close to unit. What does this mean?
More than likely the squirrel cage blower motor is defective or the blower cage bearings are in need of replacement.
Feb 07, 2012 | Heating & Cooling
Replacing wheel blower on an american standard gas furnace commercial model TDD120C960A0
This is for the main blower right? if so...
You'll want to have the replacement parts around for this, usually the only thing to break is the motor, but occasionally the squirrel cage will bust up.
First unplug the unit, then proceed to disconnect everything in the path of the blower assembly. Take note of exactly which wires go where and whatnot (taking a picture is a good idea).
The assembly itself sits in a track and is held in place by 2 1/4" hex head screws. remove those then slide the entire assembly out of the unit.
Loosen, with a small Allen wrench, the little screw holding the motor shaft to the squirrel cage.
The motor is held to the assembly with a few bolts, easy to spot, they should be 7/16th hex heads.
Remove those completely, undo the ground (green wire) then drop the old motor out of the assembly. This may be very difficult (Use the weight of the motor to your advantage).
If your squirrel cage looks fine (no broken pieces) then all you need is the new motor.*
You'll need the harness from the old motor, strap that on in the same position as it was on the old motor.
Slide the new motor into the assembly and bolt it in with those 7/16th heads. then position the squirrel cage on the shaft in a way that it rotates freely and easily, as centered as it can be, then tighten the little allen head... super tight, you don't want that to come loose.
Then slide the whole assembly back into the furnace and reverse all that previous undoing.
*If the squirrel cage needs replacing, remove the old one (it'll just pull out once you've undone the motor and a few small screws) slip the new one in, and continue.
If the wires from the motor seem confusing, green is the ground (put a loop on it and screw it to the assembly), the rest go to the circuit board. White is Neutral, Red and Yellow are spares, Black goes to "Cool" and Blue goes to "Heat". I can't remember the name of those types of plugs, but they're often available at auto parts shops. You want the 1/4" size. the neutral may be the 3/16" or 1/8th size.
May 06, 2011 | Dayton Gas Furnace Heater
Replaced the blower motor wheel.. its a flap that turns that makes noise..don't no the name
Hello: To replace the "squirrel cage" you have to replace the complete blower motor.
Jan 13, 2011 | 1995 Chevrolet C1500
It's a brand new unit but it blows air so hard and makes so much noise. Can the flow the adjusted down?
is the fan outside too noisy,if so there is no way to change the speed of this fan,the blower motor in the furnace can be adjusted,either by adjusting the centrifugal pulley on the motor shaft or electrically or installing a different squirrel cage fan on the furnace blower
Aug 22, 2010 | Goodman CLQ36AR49 Air Conditioner
Remove heater blower birdcage
if your trying to change the squirrel cage of the blower motor,
in the center of the cage,where the motor shaft comes up thru it,there is a pinch clip that you need to squeeze together and pull off,then pull cage of shaft
Dec 10, 2009 | 1999 GMC Jimmy
I want to clean the squirl cage fan on my Carrier handler. It's 12 years old and never really been cleaned. What is the best cleaning procedure to maximize its efficiency.
The best way to really clean the squirrel cage is to remove the entire indoor blower motor housing assembly out of the furnace then remove the squirrel cage from the motor shaft and pressure wash the squirrel cage. Make sure you don't use to much water pressure as you might knock off any balancing weights that may be attached to the one or more of the vanes. Make sure the cage is completely dry before you re-install it back on the motor shaft.
Nov 16, 2009 | Kitchen Ranges
New furnace, goodman and reinstalling squirrel cage... unsure where to put red wire running from squirrel cage
Mar 19, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
