Question about JVC AV-32D302 TV
Av-32d302 tv i was given this tv they said it works but needs a remote,the problem im having is this,i plug it in the timer on light flashes and i us a uni remote hit the power button on the remote the light stops flashing,hit the power again the tv starts to come on,but then shuts off and the timer light starts flashing again and then wont do anything until i un plug and plug it back in and the same thing. the orignale remote is $27 from JVC is the tv trash or is it worth the money any suggestions
  • jacob_esser Jul 29, 2008
    thank you very much for your input
  • 4,234 Answers
The set is shutting down because a problem has been detected. Replacing the remote will not help. Count the flashes and call a JVC servicer to get an idea about what the specific problem may be.
Dan
Posted on Jul 29, 2008
I have a JVC AV 32432 and the on timer light is flashing and tv won't turn on.
Flashing of timer is fault indications. Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Dec 02, 2012 | JVC AV-32432 32" TV
Received this TV from a friend, was working when it left his house, I have place on tv stand, plugged it in, hit the power button, it came on for a breif second. Now the on-timer light is blinking, I can...
what was that outside temp in transport, was it in the cold. If so the unit needed to get back up to room temp before pluging in, if not you will blow the starter.
Mar 06, 2011 | JVC AV-32150 32" TV
My remote control will not work on my TV. I have changed the batteries and tried a couple of universal remotes also with no luck. Any suggestions as to what the problem may be?
You can test your remote using a digital camera. Your phone camera will do.
Turn on the camera, point the remote at the camera and look at the screen. Press a button on the remote. You should see the LED light up. It this happens, the remote is working.
Your TV has a sensor that can see the LED's flashes. It may be defective.
Try unplugging the TV for a minute to reset the processor, that may clear the problem.
Turn off any flourescent lights or any recently added lighting to me sure that is not affecting the remotes operation.
Remove the batteries from any other remotes present (in case one is transmitting some information)
Hope these tips help.
Good luck.
Jan 02, 2011 | JVC AV-32D302 TV
My jvc av-32d302 tv has sound but i cant get an image i get just a black screen. if i unplug it and plug it in real quick i get a snow image for a second and then it goes black
There is a problem in the power supply, a defective voltage regulator or a bad capacitor. It is a good idea to call your tv repair shop and ask on what a repair would run.
Sep 10, 2009 | JVC AV-32D302 TV
On- timer light flashing no picture no sound.
hit the timer or program button on remote. see if that helps. your trying to get the picture up so you can turn the timer switch off. make sure tv is on. reply if you need more help
have a great day bama46 please rate
Aug 22, 2009 | JVC AV-32D502 32" TV
Can not turn on tv.
Just press the buttons on the TV randomly, sometimes this combination works in starting the TV w/o a remote. After that use the remote for the dish to flip channels, but you will have to set the sound manually from time to time.......sodeep
Jun 13, 2009 | JVC AV-32120 32" TV
Jvc av-32fa44 television
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
Jan 12, 2007 | JVC AV-32FA44 32" TV
TV, i plug it in, turn it on, no image, "on timer" light comes on.
If you dont hear a click theres a problem in the standby power supply. if you do hear a click theres a problem in the Main power supply or sweep supply. Get a good tech to look at this for you if your not a tech. Good Luck
Aug 07, 2006 | JVC AV-27D302 27" TV
On Timer light flashing on my TV
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. good luck!
Nov 30, 2005 | JVC AV-27120 27" TV
JVC AV-32D302 TV Logo
175 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
