Question about Compaq Presario Notebook
Spacebar stuck hello just recently my laptop has been acting a bit wacky, spacebar key was stuck and apparently i cant use it anymore.. when i boot up my laptop when it starts to load windows i just beeps a lot then shows me the hardware profile selection screen?? and then when windows finaly boots up and opens a word processor, spaces just keeps typing until i press a different key.. can anyone help me with this problem?? This is my exact problem, and it only started a few days ago. There was no warning, no issues with my spacebar previously. This has been extremely frustrating!
  • Compaq Master
  • 12,061 Answers
Ok ya gonna haveta get a New Keyboard for ya Lappy... they are relatively easy to replace they are an "All-in-one" thing and usually have a ribbon cable that plugs into the motherboard... ya could disconnect it for now and plug in an external keyboard to ya Lappy to get ya going... But be gentle getting the old keyboard out.. maybe even go online and get a Manual to see how it comes apart.. else it's off to the shop. GL
Posted on Jul 29, 2008
Spacebar somewhat jammed
There may be something stuck under the bar like a crumb of biscuit or a bit of grit that stops the bar from free movement.
Feb 07, 2014 | ASUS Computers & Internet
My spacebar on my Dell Inspiron E5015 stopped working, so I pried up the cover to see what was wrong. There are three 'keys' inside the keyboard, but only one is raised the other two are flat. The...
Not 100% on your model laptop, but on some leptop keyboards only the middle unit acts as a spring to return the spacebar to its resting position. As far as replacement with house hold items, the only thing that comes to mind is trying a fat rubberband. Cut it so its a strip and double over a few bits to make a pad of sorts.
Best of luck.
May 23, 2011 | Computers & Internet
I broke my spacebar off my laptop gateway computer! How do i fix this?
Of all the keys on the keyboard, replacing the SPACEBAR is probably the most difficult. The SPACEBAR is kept even by a metal wire that is inserted into slots on each leg of the plastic bar key. However, you have to get the wire into the slots without depressing the wire. If you push the wire down, you compress the wire and installation becomes impossible. As a general rule, do not remove the SPACEBAR unless absolutely necessary. If you remove the SPACEBAR, remove several surrounding key caps also. This will let you get some tools under the SPACEBAR wire later on. Once the SPACEBAR is reinserted, you can easily replace any of the other key caps.
Jan 19, 2011 | Gateway 2520915 Keyboard
Keyboard Spacebar does not work
you will change the space bar button
Jan 10, 2010 | Dell F3534 Touchpad
My spacebar on my acer 6390 came off please help
Hello.
Generally, the spacebar cannot be repaired, but it's worth a try:
Use a hot melt glue gun.
Turn your laptop upside down.
Put glue on the spacebar.
Press into place.
Hope this helps.
Nov 13, 2009 | Acer Aspire 5500 5570-2609 Laptop
Spacebar not responding on Toshiba laptop Satellite
Since the spacebar is the most used key on the keyboard, it is likely a hardware failure of the spacebar itself. Replacement keyboards can be found on EBay and normally run about $20
Jul 05, 2009 | Toshiba Satellite M45-S331 Notebook
Spacebar came off;wont fix now.
I don't think it is worth messing around with it anymore..Look for a replacement on ebay..Unless you get another same model and remove the needed bits..
Jun 12, 2009 | Compaq Presario C700T Notebook
Spacebar key wont click back on
get a new keyboard...those springs that need to go under the keys if you loose them they never function the same.
Feb 14, 2009 | Compaq Presario C700T Notebook
Spacebar replacement
Crazy Glue. Individual keys are not available for resale at reasonable price. You could replace entire keyboard cheaper. That is an option for you. Contact local pc shop.
Dec 28, 2008 | Acer Aspire 3680 Laptop
Spacebar stuck
you need a new keyboard most likely, contact your maker of your laptop and give them the information. you can also search up your make and model of your laptop on ebay and try to find a new keyboard that way. im 95% sure its the keyboard the rest could be software. if you have any more questions or comments pleasse email me at meanness628@aim.com
Jun 25, 2008 | Toshiba Satellite A105 Notebook
Compaq Presario Notebook Logo
148 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
