Question about Kitchen Ranges
I have a CMZ984 coleman portable rechargeable bug zapper.I have lost the manuel and charger for it.It is 4 watts.The company that made it for Coleman has gone out of business.It is about 2 years old.What do I do?
The CMZ984 takes 6 volts DC at about 850 ma or 0.85 Amp. The problem is finding a plug that will attach to the Coleman charging port. Use the Radio Shack universal DC power supply. This is a little unit that comes with an assortment of plugs and has a number of switches on the Radio Shack DC power supply. (1)-Find a plug inside of the Universal DC power supply that fits without forcing, (2)-set the voltage to 6 volts and (3)-the polarity to "+". When the universal power supply is plugged into the bug zapper and the universal DC power supply set at 6 volts, turn on the BUG ZAPPER. If the lights inside turns on when the battery is dead then you probably have all switches set correctly. At yard sales, this UNIVERSAL power supply sells for about $1. It comes with a number of different plugs. Don't forget to write the voltage and polarity on the bottom of the bug zapper for the next time.
Posted on Aug 21, 2011
I opened up the lantern with the battery inside and looked to find out the voltage,have not found the charger yet,but at least I have more information on how to get one.
Posted on Jul 29, 2008
  • bobhanson Sep 27, 2010
    I have a coleman portable bug zapper new in the box, never used, see my CL add. http://minneapolis.craigslist.org/wsh/sp... contact me if this interests you.
  • rhemsher Jun 17, 2011
    Bob,
    Is the zapper still available?
    email me at rhemsher@erols.com
Had the same problem...was lucky enough to find my charger. Model No. HY-05-6, made in China. 6V 830mA - doesn't say if it's pos-center or neg-center. Searched the web and the best I could come up with was a company in Australia - www.accesscomms.com.au Their page loads as a pdf file, but their email address is located at the bottom of the page. If I recall correctly (and my recollection is a little hazy after the 1960's), you may be able to fudge a little on the mA's without frying the circuit -- I'd check w/ Radio Shack and see what they have to say. Good luck!
Posted on Sep 05, 2008
My charger says 6 volts dc, 830 Ma.
Posted on Aug 24, 2008
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
What weight oil do I use for a 5000 watt Coleman generator
Depends on the temperature where yuo will operate it, but a good multi-viscosity oil like 10W-30 should work. 5W-30 for cold climates.
Sep 07, 2014 | Coleman Powermate 5000 Portable Generator...
Battery and charger
You can get aftermarket 18V rechargeable batteries that may interchange with your Coleman battery and may even use the same 18V charger
May 11, 2013 | Coleman Cable Coleman 18 Volt Combo Drill...
Do i mix oil in the gas on the coleman powermate 8750 honda 13 hp?
Hi, no you don't. It is a four stroke engine and uses engine oil in the sump only. Regards Phil.
Jul 28, 2011 | Coleman Powermate 7,000 Watt 13 Hp...
How many watts is the Coleman Powemate Premium Plus 6250W portable genr
Hi, the constant delivery is about 5000 watts and the peak delivery is as the name says 6250 Watts. Hope this helps.
Nov 18, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM049700 need to know what kind of oil to use and replacement sparkplug
we need to know the make of the motor....most use a SAE30 four stroke oil....not sure of the plug without knowing the make of motor.
Jul 23, 2010 | Coleman Powermate 7,000 Watt 13 Hp...
The coleman rechargable blender not blending
Subject: Rechargeable Portable Blender Model No. 850-870
I was given one of these blenders for Christmas. I charged it through 3
cycles, used it once and the battery was dead. Charged it through another 5
charge cycles and used it once only to then have another dead battery. I
have put it through at least another 8 charge cycles, and it indicates a
DEAD battery. I have managed to blend two (2) 3/4 full pitchers in total. On
trying to start it now the green light 'flickers' quickly on and shuts down.
This is a totally useless device.
I would like to return it for a full refund, including shipping.
Dec 21, 2009 | Coleman 850-870 Single-Speed Blender
I have a 4000 watt Coleman generator that won't
If it has been in storage with gas in it. it is gunked up. Need to remove carburetor and take to someone to clean carb.
Aug 23, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Kitchen Ranges Logo
2,099 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
