Question about Crocs Croc Classic Flat Iron Titanium Black Plates 1"
My croc iron will not heat up. It will not get any hotter than 69 degrees Fahrenheit.
  • 4 Answers
Reset it and it will work fine! To reset it: plug it in and hold down the power button for about 20 seconds.
Posted on Nov 29, 2011
  • Cassia Gonzales
    Cassia Gonzales Nov 11, 2013
    I am holding down the power button and its not doing anything. What else can I do?
    New Friend:
If your iron won't reset (As mine didn't!) just place it (being extremey careful) over a hot surface (just touching the ceramic part of the iron and ONLY the ceramic!...I did it with a small butane torch just heating the ceramic flat surface) to "force it" to go over that boring 69 number. Let i go as high as you can, preferably up to 450 F and...Voila! after that the iron will work perfectly!
Posted on Nov 08, 2015
Mine wont either.....!!!!! :(
Posted on Feb 28, 2011
Need to change thermostat from Celsius to Fahrenheit
The first link is operators manual.
The second is installation and contains the procedure to set many functions including the display temperature.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2577ES.pdf
See page 15 function set 14. This sets F or C temperature
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2578ES.pdf
hope this helps?
Jun 23, 2017 | Honeywell Heating & Cooling
How to take apart croc infrared flat iron 1.5
I can't tell you how to take it apart, but you might visit www..flatironrepairs.com and contact to see if it could be repaired.
Dec 15, 2012 | TurboIon Croc Infrared Flat Iron 1 1/2"""
Croc flat iron won't turn on
You might visit www.flatironrepairs.com and contact them to see if they could repair it. It's only $46.00 for the repair + s/h.
Dec 04, 2012 | Crocs Croc Infared Flat Iron 1"
How to Reset a Croc Infared Flat Iron 1
Mine does that too! And I don't know what to do!
Jun 07, 2012 | Crocs Croc Infared Flat Iron 1"
Says err and shuts off
Same thing happened to me, I just reset it and it works perfect again!
* to reset it: Plug your straightener in and hold the power button for about 20 seconds to reset it.
Nov 08, 2011 | Crocs Croc Classic Flat Iron Titanium...
Croc only heats up to 230 degrees is there a way to reset it
CHANGE TEMPERATURE SETTING from CELSIUS to FAHRENHEIT
To Change the Temperature Setting from CELSIUS [230 Degrees] to FAHRENHEIT [450 Degrees]
If [230] appears on the display screen, then the temperature is set to Celsius. To change back to Fahrenheit:
1. Turn off your flat iron and unplug from electrical socket (wait for 10secs).
2. Then plug the iron back into the electrical socket.
3. Press & hold down the HIGH [?]button, then press ON/OFF button. An "F" will appear on the digital screen. Your device is now in Fahrenheit mode.
Jul 23, 2011 | Crocs Croc 2 Flat Iron Titanium Plates 1"
My croc flat iron goes to 69 than shows error message
It's not working! I've tried unplugging it for a minute, plugging it back in and holding the power button on....am i missing something. I've had this damn thing for about 2 months. Please dont tell me i have to buy another one....AAAHHHHH!
May 28, 2011 | Crocs Croc Classic Flat Iron Titanium...
My oven won't heat above 255 degrees. just curious what the problem might be.
You do not state if this is in centigrade or fahrenheit.
If it is centigrade, then it will not reach more than this if it is a domestic oven, if fahrenheit, then it should get hotter, so I would suspect a faulty oven thermostat as being the cause of the problem
Jan 05, 2011 | Ovens
When i change the temperature to make it hotter, the screen blinks then goes back to being 30 degrees colder. Is my heater ignoring my request because it never reaches the temperature i want it to. it...
First you have to understand in thermostat there are Fahrenheit & Centigrade degree. If Centigrade between 16 to 30 and if it is Fahrenheit 60 to 86.
If you press the symbol ther> and > (or) ther- and ther+ at a time degree will change.
Now you set your temp +10 degree from your room temp and also keep "heat" mode.
Dec 14, 2010 | Heating & Cooling
Crocs Croc Classic Flat Iron Titanium Black Plates 1" Logo
4,364 people viewed this question
Top Crocs Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Crocs Health and Beauty Expert? Answer questions, earn points and help others
