Question about RCA Universal Remote Control
RCA Universal remote
Hi i have a RCA Universal remote. I lost the manual to it and i want to program my tv and dvd/vcr to it. It does not have a code search button and i cant seem to find any instructions for ones that dont have that button can you help me? The bottom of the controller has a code of RCR 615 DCM1.
  • 4 more comments
  • lacy507 Dec 01, 2008
    I have the same problem.
  • Anonymous Jan 07, 2009
    Same as above. I lost the manual to it and i want to program my tv and dvd/vcr to it. It does not have a code search button and I cant find any instructions for ones that dont have that button. The bottom of the controller has a code of RCR 615 DCM1.
  • hollowsoldie Jan 18, 2009
    There is no setup button on this particular model. What are you talking about?
  • Anonymous Jan 18, 2009
    i need the manual so I can program my TV
  • Anonymous Jan 19, 2009
    I can't find my manual to program my rca servicelink 3 remote controle
  • Batebulldog Jan 22, 2009
    I have a GFM 19" TV from Meijers and a RCA DTV DTA800B1 Converterbox with remote controller. I can't find the code to program the DTV converter box remote controller. It is not listed in the instruction book. Please help.
I have a rca remote model and a sharp t.v. the remote# is rar450,1650 ew,need to know how to progam to t.v.
Posted on Jan 09, 2009
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): RCA Universal remote - clip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
2 Suggested Answers
  • 1274 Answers
SOURCE: How do you program an RCA
Turn TV on, press and hold down the CODE SEARCH or SET-UP button, press the TV button while still holding down the CODE SEARCH button, the light will blink once, release CODE SEARCH button, press the on/off or the POWER button until the TV turns off, may take as many as 100 tries, once it turns off, press ENTER button....hope this was helpful...
Posted on Apr 29, 2010
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
MAGNAVOX UNIVERSAL REMOTE
hi have you tried scanning all codes with the remote untill it picks up the correct signal if you have the manual it will tell you how to do this if its possible it will work after searching the codes.
Also what model remote and what make cable box
Mar 29, 2008 | Philips Magnavox Learning Universal Remote
How do I program my RCA TV with a RCA remote and DVD/VCR that is a JVC
HI,
CHECK THE FOLLOWING LINK . ON SEARCH TAB TYPE RCA . YOU WILL GET ALL THE LISTED RCA REMOTE CODES AND HOW TO PROGRAM IT.
Electronics Equipment Repair Center
Jul 13, 2014 | RCA RCU403N Universal 3 Device Remote...
I have a Trutech PLV1615T TV and a RCA RCR311 Universal Remote that I lost the info for. How can I get them to talk to each other....Thanks, Tom
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: y TV-000 y VCR-000 y Cable Box-000 y AUX is programmed with VCR code 037For brands that require programming, there are two ways to program: Using Code Lists or CodeSearch. Use Code Search if the code lists are not available or if the codes from the lists do notoperate a device.Programming a Device using Code Search:1. Manually turn ON your device (TV, VCR, Cable Box)2. Press and "HOLD" CODE SEARCH3. Press and release the device button you want to set up (TV, VCR, Cable Box) However,if you are using AUX for a device, press and release AUX first and then the devicebutton for the type of device to be programmed (TV, VCR, or Cable). The selecteddevice button will flash once.4. Release CODE SEARCH.5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100times at a rate of once per second).6. Once the device turns off, press and release ENTER.7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6...Hope this helps! Parsos215
Sep 20, 2011 | RCA Universal Remote Control
Hello i have a toshiba md9dm1 tv/dvd combo and i lost my remote I have a universal ge remote none of the codes work Do you know the code for my tv/dvd combo?
hi,
If you remote is a 4 digit one then the codes are
0394, 0924
If the remote is a 3 didgit one then the codes are
394, 902
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the
INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR,
DVD, etc.). For AUX, press AUX then the device button you are assigning to
AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the
GE Universal Remote. After your code is entered the INDICATOR LIGHT will
turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER
button. Your device should turn off
OK
Aug 03, 2011 | Toshiba MD9DM1 9 in. TV/DVD Combo
I HAVE A RCA 3 DEVICE REMOTE CONTROL AND LOST THE MANUAL.I NEED THE CODES TO PROGRAM IT. WHAT DO I NEED TO DO?
HI, Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search: 1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote 2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Nov 06, 2010 | RCA Universal Remote 3 Device Remote...
Hi Iam trying to program a universal remote control to my sansuni tv vcr dvd combo but haven't had any sucess. I have tried to do it with several different universal remote but none of the codes seem to...
How old are the remotes relative to the TV in question? If the remotes are older than the TV or were programmed within 6 months of this TV being released, then the code you need wasn't included in the remote's programming. In addition, unfortunately, many universal remotes do not work on combination TVs (with the DVD player and VCR built-in).
You can try to search through all the codes for the remote if your remotes have that feature. (On RCA remotes, turn on the TV, press and hold the Code Search button until the indicator light comes on, then press and release the TV button. Then press the On/Off button repeatedly until the TV turns off. Press Enter and see if the other functions of the remote work. If they do not, repeat the search. Then do the same but press the DVD and VCR buttons instead of the TV button.)
More likely you need a newer universal remote, a programmable (via computer USB) universal remote or a substitute remote from the manufacturer. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12845952409830&smodel=TDC2075&brand_pn=SANSUI_TDC2075 for an exact substitute remote that will replace the original remote.
I hope this helps.
Sep 15, 2010 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
I have a rcr312wr,I lost manual,I want conect it to dvd samsung...which is the code and the steps???
HI,
Direct Code Entry:
Code Search:
Thank you
Sep 15, 2010 | RCA 3-Device Universal Remote with...
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
I lost my codes and directions on how to program my universal rca remote
Hi ,
I have given the following links which have the step by step process for programming universal rca remote
http://www.thompsontv.com/rcarc.html
http://www.ehow.com/how_9191_program-rca-universal.html
Thank you!!
Jul 22, 2008 | RCA Audio Players & Recorders
Televison & Video Logo
1,893 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
