Question about Ulead Videostudio 8 for PC
Easy Cape USB Capture Device
I get a picture, but it's pixels and I can't get a clear picture no matter what format I use. In my system properties it tells me that my EasyCap is working properly. I have Windows XP and Windows 2000 and same problem on both. Ulead doesn't work. Nero I get the picture by all pixels. My brother has the same XP and it works fine on his computer. The only thing I have different on my computer is my that my Video Card is an ATI All In Wonder. Would that cause this problem? Thanks for any help you can give me, it's driving me nuts. Linda
  • Vampy13 Jul 30, 2008
    I will check that over the weekend. Thanks.
    Thanks for the input, I will check that this weekend.
    Champion:
  • 258 Answers
Your card is fine. I think your INPUT is not configured properly. R u using firewire if yes then check drivers. CHECK PREFERENCE ON SOFTWARE
Posted on Jul 30, 2008
Pen drive is slow
Slow Transfer on a USB Flash Drive b> Using a USB flash drive is a convenient way of transferring data and files from one device to another. However, sometimes you may find that your USB drive is slow to transfer files onto your laptop or PC. This lag may also cause your desktop or laptop to slow down while you use other programs. You do not need to replace your flash drive and buy a new one. You can fix a slow file transfer problem in just a few steps.
b>Plug your USB flash drive into your computer. Click the "Start" button and select "My Computer." Right-click the USB icon from the My Computer window and click "Properties" from the menu that comes up. Go to the "Hardware" tab and select your flash drive once you find it in the list of items. Then click the "Properties" option in this menu. Choose "Policies" tab within the Properties menu. Turn on the performance optimization option and click "OK." Click "OK" again to exit out of the Properties dialog box. Go back to the My Computer window and right-click on the USB icon. Select the "Format" option from the list of choices. Select the "NTFS" file system and choose "Quick Format." Press "OK" to confirm the choices and to initiate the formatting. Wait for the drive to finish formatting before ejecting it and removing it from the computer.
USB Flash That Is Slow and Damaged
b> USB flash drives are used to transport data between computer systems. Because it is essentially just a small hard drive, the USB device can become damaged and slow down in performance due to viruses or damaged files. To correct these problems and fix the USB flash drive, you must reformat the drive. This removes all data from the drive, returning it to its factory settings.
Plug the USB flash drive into a USB port on the computer system. Close any AutoPlay window that may load onto the screen. Click "Start" then "(My) Computer." Right-click the removable device icon that appears on the screen. Select "Format" from the pull-down menu. This loads a format options screen. Click "Yes" and the computer formats the USB flash drive, removing the damaged content and returning it to the factory settings.
ReadyBoost With a Slow Flash Drive
b>The ReadyBoost feature in Windows has the ability to increase the speed of low-RAM computers by caching program data on a flash memory device. However, the device must meet minimum performance characteristics in order for Windows to enable ReadyBoost, because ReadyBoost may not meet expectations when used on a slower device. If you still want to use ReadyBoost with your flash drive or memory card, you can make a change in the system registry to force Windows to use the device.
Insert the flash device that you would like to use for ReadyBoost. Open the Start menu, and click "Computer" to see the icon for the device. Right-click the icon for the flash device, and then click "Properties." Click the "ReadyBoost" tab at the top of the window. Clear the check from the "Stop retesting this device when I plug it in" box, and then click "OK." Remove the flash device. Open the Start menu again. Type "regedit" in the "Search programs and files" box at the bottom, and then press "Enter" to run the Registry Editor. Double-click the folders "HKEY_LOCAL_MACHINE," "SOFTWARE," "Microsoft," "Windows NT," "CurrentVersion." and "EMDMgmt." Locate and click the folder for your flash memory device under "EMDMgmt." In most cases, you can determine the correct folder because it contains the name of the device's manufacturer. Double-click the registry entry "DeviceStatus" on the right side of the window. Change the number under "Value Data" to "2" and click "OK." Double-click "ReadSpeedKBs" on the right side of the window. Change the value to "10000000" and click "OK." Repeat this process with the "WriteSpeedKBs" registry entry and close the Registry Editor. Reinsert the flash memory device, and return to the "Computer" window. Right-click the icon for the flash memory device, and then click "Properties." Click the "ReadyBoost" tab. Windows now displays an option to enable ReadyBoost on the device. You might install a usb 3 card the speeds are much faster cheap and easy to install. Hope this helps.
Jan 08, 2013 | Electronics - Others
I dont have the disk for my web cam GE 98090 how can i get the driver ?
It says that it doesn't need a driver since it follows a universal driver included in windows. GE Perfect Image Webcam (1.3 Mega Pixels) Our Products: GE Computer Accessories > GE Webcams 98090webg1.jpg GE Perfect Image Webcam (1.3 Mega Pixels) 98090webg1.jpg GE Perfect Image Webcam (1.3 Mega Pixels) 98090webg2.jpg GE Perfect Image Webcam (1.3 Mega Pixels) (Click to see larger image and other views) hs.align = 'center'; hs.transitions = ['expand', 'crossfade']; hs.outlineType = 'rounded-white'; hs.fadeInOut = true; hs.dimmingOpacity = 0.3; //hs.numberPosition = 'caption'; if (hs.addSlideshow) hs.addSlideshow({ slideshowGroup: 'slides', interval: 3500, repeat: true, useControls: true, fixedControls: false, overlayOptions: { opacity: .75, position: 'top center', hideOnMouseOut: true } }); function pcf_initEnhancement(ele,img) { if (document.getElementById('1')==null) { hs.expand(ele, { src: img, minWidth: 250, minHeight: 250 }); } else { document.getElementById('1').onclick(); } } SKU: 98090 Capture clear videos and sharp images with the GE Perfect Image Webcam. More details... Price: $54.99
icoaddtowishlist.gif icotellafriend.gif addthis_pub = 'jascoproducts'; addthis_brand = 'Jasco Products'; addthis_options = 'favorites, digg, delicious, myspace, facebook, google, live, furl, reddit, twitter, ask, technorati, stumbleupon, more'; icobookmarkshare.gif Product Details Capture clear videos and images photos with the GE Perfect Image Webcam. Capture high quality hands-free audio and broadcast through the built-in microphone. The stand can easily be adjusted to your desktop or clipped to your laptop or monitor. Complete with ArcSoft® VideoImpression™ and PhotoImpression™ editing software to capture, edit and customize images and videos.
Features:
  • Built-in microphone
  • Snap shot button - Easy to use for great still photos
  • Hassle free focus - Ensures crystal clear videos with adjustable focus ring
  • ArcSoft® Editing Software (Included)
  • Adjustable stand - Steady base ensures stable videos
  • Compact size - Provides convenience and portability, perfect for travel and laptop use
System Specifications:
  • Sensor: CMOS with 1.3 MP
  • Resolution: up to 1280x1024
  • Video frame rate: 30 frames per second
  • Color depth: 24 Bits, RGB True Color
  • Focus range: 10 cm -- infinite.
System Requirements:
  • Computer with USB port
  • 350 MHz recommended
  • 64 MB recommended
  • Windows® XP SP2 or Vista
  • 100 MB free hard drive space
  • 16 bit video display or higher
  • CD-ROM Drive
  • Universal Video Class no drivers
Nov 12, 2010 | GE 98090 Webcam
When I capture video from vhs, the result is a lot worse in quality than the original tape. I have tried capturing avi and mpeg, it makes no difference. fixed bitrate at 8000, no difference. Highest...
If you have the option, try capturing your video as MJPEG or DV format without compression, also the resolution must be 720x480 pixels (for NTSC) or 720x576 pixels (for PAL).
It will create a huge file !!! After this I recommend a dvd conversion with deinterlacing for better picture quality.
Hope this helps!
Oct 07, 2010 | DekCell EasyCap USB 20 Video Capture...
I need picture package software
Forget those software.
Even windows movie maker can do as good job (if not better than) those pic.package thing.But you need to use Firewire cable&card to do the job.Firewire connection is also far superior than USB cable connection,too.
-Stable,trouble free data transfer during video capture.
-Video transferred at its maximum resolution 720*576 pixels or something like that compared to 340*240 via USB transfer.
-100% supported by any video editing program,even the simplest Window Movie Maker.In other words,forget Sony's software - use something else that wouldn't run you.
Of course,those Firewire cable&card might be not very globally available like USB device.But still easy to find and relatively cheap to buy anyway.
Aug 06, 2010 | Sony Handycam DCR-HC20 Mini DV Digital...
How to upload pictures by my usb
That really is a matter of if when plugged in to the USB port of the computer you are using, if computer you are using can recognize the drive.
If you are using Windows XP, check "My Computer" and you should see the Kingston USB jump drive showing as an device icon.
In Vista and Windows 7 select "Computer" and you should also see the USB jump drive listed as a device icon.
If you are using a Mac OS X computer with your Kingston jump drive, providing the drive has been formatted with the Mac OS Extended (Journaled) format, or the MS-DOS format (which is readable on both Mac and PC platforms), it will show up
in the Finder sidebar and on your Desktop.
Either platform however, to load pictures onto your Kingston is easy, all you have to do is either copy the pictures from there respective folder or location and either right click on the Kingston 2GB HD icon and paste the pictures.
Or you can double click on the Kingston 2GB USB icon and paste or drag the pictures into the open window of the Kingston 2GB USB jump drive.
That is honestly as simple as it is.
Now, on the other hand, here are a few steps, if you want to upload to an online resource which allows photo uploads from another source, namely your computer..
When you use the upload feature of that website or webpage to upload your pictures to, no matter whether you are on a Mac or PC, you simply have to click that uploader's Browse or Upload button.
Next, simply locate the Kingston 2GB USB jump drive in My Computer, (Windows XP), Computer (Vista , Win 7) or Devices and/or Desktop (Mac OS X).
Then start selecting and uploading your pictures onto that website or webpage with your Kingston as the source drive.
Yes, I have given you a number of options, but hopefully you will see the ease of using any of these methods, again depending on what computer operating system you are using, how easy it is to upload photos from your Kingston (DTIU3/2GB) 2 GB USB Hard Drive.
Regards,
-Mactechtrainer
Jan 31, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Can't Detect Camera DCR-HC19E
Check properties of Picture Package or reinstall software to clear any bugg in it.
Jun 20, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Cannot get sound or colour to work
Sound:
I had exactly the same problem and solved it by updating the drivers for the USB sound/audio device.
My XP version is in Swedish so I´m not sure what it says in English, but it should say something like the following.
Go to the "Device manager" by right clicking on "This computer" and choosing "Properties", locate the "USB sound/audio device" under the "Sound, Video and Game"-category and right click and chose "Update drivers". Then chose "Search for drivers on the internet" and chose "Recommended installation".
My new drivers are called "USB EMP Audio Device". They work perfectly. Of course you have to chose these drivers under "Options/Input source".
I wasn´t able to update the actual EasyCap video adapter, but it doesn´t seem to matter if you´re having problems with the sound.
Video:
Click on "File", then "Preferences" then "Capture" flap, check the "Allow access to capture device´s settings" box, click "OK". Go the the "Capture" flap in the main window and chose "Capture video". Now you should see "Options", click and chose "Capture properties", then "Video capture filter", click "Properties" in the same window and the chose the correct "Videostandard", for example "NTSC" for USA and "PAL" for Europe. Try all of the alternatives until you get a picture.
Make sure you have chosen the right input source under "Options (see above/Input source". Chose Composite or S-video (you´re likely using composite). I can´t use an S-videocable, only a videocable, otherwise the picture turns black and white.
Now you should see something, if not, maybe something went wrong when you installed the drivers/software.
Hope this helps!
May 15, 2008 | Ulead Videostudio 8 for PC
Distortion of picture on other side
Technical Specifications
  • Quality CiF (352x288) CMOS webcam
  • Video capture: 640x480 pixels (SW enhanced)
  • Still image capture: 640x480 pixels (SW enhanced)
  • Frame rate: Up to 30 frames per second (with recommended system)
Nov 23, 2007 | Logitech QuickCam Chat Personal Web Camera
EasyCap Video Capture
Hi
I had the same problem. No picture and no sound.
Here is what I did to solve it.
1. I Un-installed the software and restarted the computer.
2. Placed the installation CD (that came with the product) back in the CD drive.
3. Click on "Install Driver" (this only installs the USB 2 drivers so that the computer can see the device)
Make sure you do not attach the Easycap Device before you have installed the USB Driver (as above).
4. Once USB Driver has been installed then plug in the Easycap USB Device, windows should then detect the new device, to make sure:-
5. Right Click "My Computer" "Properties" "Hardware" "Device Manager" check "Imaging Device" (which is where my STK1150 Driver was installed) and make sure it has no yellow exclamation mark next to it.
6. Go back to CD and "install the Uplead Software", you then have to Restart the computer.
Once all installed you can then connect your external device VHS Player/Camcorder etc to the Easycap device, using the Red/Yellow/White leads.
I like many before me, tried and I tried to get the image to play on the software "Capture" screen but all to no avail, I was pulling my hair out, I wasted two days on it, I finally decided that this product was a total load of rubbish and I had wasted my money and it had to go.
Then a major break through, some smarty pants made the comment about INPUTS & OUTPUTS, my prayers along with many others could have been answered ??....
I had actually plugged the Red/Yellow/White leads into the INPUT terminals of the external VHS Player, when they should be plugged into the OUTPUT terminals of the external VHS Player/Camcorder.
On a Camcorder the RED/Yellow/White terminals are usually Output terminals but on a VHS Player they are usually always Input only !!....
I tried running my Camcorder through the software and Hey Presto that worked a treat.
So in order to get my VHS to play through the software I ended up having to buy a Scart OUT (very important "OUT") Red/Yellow/White adapter (see link for product image)
http://www.maplin.co.uk/Search.aspx?criteria=scart%20out&source=15&SD=Y
Once all connected I pressed play on the VHS Player and I have to say that nearly fell off my chair "IT WORKED - IT WORKED - IT WORKED"
Sep 30, 2007 | Ulead Videostudio 8 for PC
Ulead Videostudio 8 for PC Logo
134 people viewed this question
Top Ulead Computers & Internet Experts
Barbat Nae
Barbat Nae
 Grubhead
Grubhead
Daniel Florin
Daniel Florin
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
