Question about OKI KIT-C3530N MFP LASER CLR P/S/C/F USB ENET 1200X600 128MB Printer
OKI C3530 MFP
Service call
155: fatal error
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
Looks like a fuser problem.
Re-saet the fuser.
Check for pieces of paper, etc. in the path.
Service call 155: Error
Defective fuse
cutting of fuser
Is the fuser installed correctly?
Does the error recur?
Yes
Reinstall the fuser after its
connection connector is cleaned
Turn on the power supply again
If error still exists_
Replace M32 board after check
the cable connection.
Posted on Dec 07, 2008
How can I fix oki c3530 231: fatal error 03?
RFID Reader I/F Error An interface error was detected
with the RFID reader device.
01: communication error between
the RFID reader and the engine
PCB.
02: the transceiver circuit error of
the RFID reader.
03: communication error between
the RFID reader and the Tag
chip.
04: the RFID Tag detection error
Jun 21, 2014 | OKI C5800Ldn Led Printer
I have an oki c3530 and it is making a terrible grinding noise, any ideas?
One of the drums needs to be replaced. Systematically remove one at a time until the grinding noise no longer happens, then replace that drum.
Jan 26, 2010 | OKI C3530N Color MFP Printer
073 fatal error in OKI c3530
Oki ERROR 073 is a H/W Overrun detect. this occurs when the video circuit has set the overrun bit. Restart the printer and check the first print out. Try printing a different job and then reprint the same job that the error occurred. If you get the same error again, try using a different driver, ie swap from PS or PCL whichever you were using to see if that clears the error.
Dec 28, 2009 | OKI C3530N Color MFP Printer
PRINTER NOT WORKING
That is a fuser code. Turn off and take out fuser(the part that gets hot) and inspect it. Put it back in and turn back on. If code is still there replace fuser.
Aug 02, 2009 | OKI Electric Industry C3520 Laser Printer
OKI 3530 MFP Service call: 150
Your error 150 is the toner sensor board not making contact with a drum and therefore not blowing its fuse. Remove the Main board and you will find the toner sensor board behind it. It has a lot of metal contact springs and you will most probably find one is out of position and just requires removing and refitting. If still not working the part number for the board is: 43614901 OR-Board-PRS
Good luck.
Jul 09, 2017 | OKI B4350 Laser Printer
OKI C3530 Fatal Error 031
Hi.. i only remove the memory ROM in the board and refixed it, then i turn on the printer and now its working :)
thanks Admin
Feb 19, 2009 | OKI C3530N Color MFP Printer
OKI C3530N Multifunction Printer
Check the left side of the drum cartridge.
There's a little door that may be stuck closed.
Carefully push it open with a small screwdriver.
Oct 31, 2008 | OKI C3530N Color MFP Printer
Error Code 155: Fatal Error
Looks like a fuser error-
re-seat fuser
check for paper scraps, etc in fuser and printer.
Service call
155: Error
Defective fuse
cutting of fuser
if error still exists-
Jul 29, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
OKI KIT-C3530N MFP LASER CLR P/S/C/F USB ENET 1200X600 128MB Printer Logo
1,144 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
