Code 30 is the anti flood switch.
You have a leak and water has gone into the base and operated the anti flood switch which will make the drain pump run until you disconnect from the mains.Tip dishwasher on its back to get the water out of the base and reset the anti flood switch. Now retry. If it floods again you have a leak inside and need to find out where it is coming from
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Thank you, but can I ask where we locate the anti flood switch, as I dot not have users guide
