Hello 0002 0502 0006 0115 0506 0706 0520 0906 0316 0505 0614 0324 0924 0626 0826 0027 0327 0128 0228 0632 0134 0247 0605 0705 0805 0703 0903 0004 0519 0106 0104 Direct Code Entry 1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button. 2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit. 3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes. 4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of Code Search (by Brand) Lets you search for a code for a specific Brand within the Code Library for a particular manufacturer. 1. Turn on the device (TV, VCR, etc.) to be controlled. 2. Press and hold the CODE SEARCH button until the red indicator remains on, then release the CODE SEARCH button. 3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks off once. 4. Press and release the numeric button (0-9) corresponding to desired Manufacturer (see table below). Note, pressing "0" performs a full library search same as Device Library Code Search Method. 5. Press the CHANNEL UP button ((or POWER or PLAY (VCR only)) repeatedly until the device to be controlled changes channel. 6. Press and release MUTE to install
Your Philips CL 034 model remote control should work with almost all models of Emerson TV. Codes to check with are
0304 0604 0804 0005 0105 0305
Be patient and check with these codes one by one, till you find the code for your Emerson model.
NB: Switch OFF and switch ON your TV set, with its front panel power control switch, before trying an other code.
Proceedings
the other codes for your brand.
the code.
OK.
Code Search (by Device)
If after trying “Direct Code Entry” or
“Code Search (by Brand)” your device
does not respond, or if your brand is not
listed, try doing a device search of the
code library for your code by following
the steps below.
1. Manually turn on the device (TV,
button.
4. Press the CHANNEL UP button
repeatedly (up to 300 times) until
channel. The red indicator blinks,
then stays lit.
5. Press and release MUTE to install
the code.
Most users will want to store VCR
codes under the VCR button, Cable
codes under Cable, etc. If you want to
store a VCR code under Cable, etc., first
follow the procedure for Direct Code
Entry and press Cable in step 2 of
Direct Code Entry, then enter ANY
VCR code in step 3 of Direct Code
Entry. Then follow the steps above for
Brand Search or Complete Search.
