Question about Kodak EasyShare Z1275 Digital Camera
Take apart Kodak EasyShare Z1275 ?
Anyone have instructions on taking this camera apart?
I'd like to try to see if i can clear out some sand that probably inside
the lens mechanism.
  • adamkbrown Aug 31, 2008
    I dropped this camera in the river 2 weeks after getting it. It works fine except for a water spot in the middle of the screen from my drying out process.
    Anyone know how to take out the lens and wipe it off?
5 Suggested Answers
mads_aye
  • 58 Answers
SOURCE: Kodak EasyShare M753 bent lense
if the camera will be sent it to the authorized repair center, the repair cost is arranged according to model, not issue
the repair cost of M753 is around $60-65 + local tax + kodak's shipping and handling
www.kodak.com/go/itg to arrange repairs - you can also see the repair cost from the website and other options if you think it's not worth it
Posted on Feb 13, 2008
mcomijohns
  • 477 Answers
SOURCE: BROKEN LCD KODAK Z1275- NEED INSTRUCTIONS ON HOW TO REPLACE
The LCD is pretty east to replace once you remove the case screws the case will separate with a little force make sure you mark down the screw "possion". This can be crucial now once the case is off. be careful the LCD can have 2 wires and a ribbon cable or 2 ribbon cables or just 1 ribbon cable. their will be a latch at the end of the ribbon cable lift it up and remove the ribbon cable if their are 2 do the same to both. if their are soldiered wires make sure you remember witch potion they were in. and put the new LCD in the same way you took the other one out. OH YEAH WATCH OUT FOR THE FLASH COMPOSITOR. It can bit like a starving dog on a steak bone. 300 volts is enough bite to make you through the camera across the room LOL take it from me I know LOL. Well just reverse the steps and you should be ok. Hope this helps.
Posted on Apr 22, 2008
Most of the time, if you can get a sharp knife to SLIGHTLY dig into the part of the tube that is bent, you can CAREFULLY wedge the tube back out. (With the camera OFF) then when you turn it back on, the camera will reset the lens and all will be ok. I've done this with three cameras so far.... ALL involving 13-year-olds dropping them!!! What is it with 13? Unfortunately, MY 13 year-old, smacked the 2.5 inch screen, and the crystal broke... Other than a $50 part on e-bay, I'm having trouble finding a REASONABLE priced replacemement...
Sigh....
Posted on May 19, 2008
SOURCE: kodak easyshare z1275 not working =(
ghgfh
Posted on Sep 15, 2008
  • 225 Answers
SOURCE: kodak EasyShare C743 takes blurry pictures 80 percent of the time
It is a bad lens focus motor.
Posted on Nov 17, 2008
Can I use the same USB cable to charge the batteries as well as transferring photos to computer from Kodak EASYSHARE Z1275 12.0 MP Digital Camera providing that I am using rechargeable batteries inside the...
No. The Z1275 is not a battery charger. If you want to use rechargeable batteries then you must charge them outside the camera using a separate battery charger.
Aug 19, 2013 | Kodak EasyShare Z1275 Digital Camera
Looking for the instruction manual for the Kodak easyshare z1275
You can download and print the instruction manual in PDF format by clicking these links:
User guide
Extended User Guide
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Sep 19, 2010 | Kodak EasyShare Z1275 Digital Camera
Kodak V1253 lense won't close
Use the vacuum cleaner to suckout the dust/sand particles stuck between the lens casing and the body.
Aug 11, 2009 | Kodak EasyShare Z1275 Digital Camera
My Z1275 kodak camera's lens wont retrack. turn it on and then it goes right off.
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
May 04, 2009 | Kodak EasyShare Z1275 Digital Camera
Shuts off when i try to zoom.....
I was also having a similiar problem with my z1275 and tried the "vacuum" thing. BINGO! It worked, and I was about to send the camera back to Kodak for servicing. You saved me money.
What did I do?
I turned my vacuum on, stuck my lense into the vacuum tube, zoomed all they way IN and then turned the vacuum off. My camera now works perfectly.
Before using the vacuum, I was only able to zoom about 50% before the camera would turn off. Thanks for your help.
Jul 29, 2008 | Kodak EasyShare Z1275 Digital Camera
EASYSHARE Z1275 Digital Camera
KODAK EASYSHARE Z1275 is a peice of ****
Jun 28, 2008 | Kodak EasyShare Z1275 Digital Camera
Kodak EasyShare Z1275 Digital Camera Logo
277 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
