Well, here's the instructions from the service manual. The labor guide says this can be done in 1.6 hours...I don't see how, unless the instructions are wrong about having to remove the instrument panel. My thoughts are that if you are only doing the blower motor, the blower assembly will come out without pulling the dash. You probably only have to do a partial disassembly and remove the glove box and the glove box lower support. ************************************************************************************* BLOWER ASSEMBLY Removal and Installation 1. Disconnect battery ground cable. Remove Instrument panel. (See Instrument Panel Removal) Disconnect resistor connector. remove blower assembly duct. Disconnect motor connector. Remove blower assembly 2. Remove blower assembly screws and blower motor assembly. Remove clip and fan from assembly. Separate motor case and remove blower motor. To install, reverse removal procedure. INSTRUMENT PANEL Removal 1. Disable air bag system. See AIRBAG RESTRAINT SYSTEM article in ACCESSORIES/SAFETY EQUIPMENT SECTION. Disconnect negative battery cable. Scribe mating marks on steering wheel and shaft for installation reference. Using Steering Wheel Remover (J-29752) remove steering wheel. Remove steering cowl. 2. Remove instrument panel grilles and plug, or driving pattern indicator panel (A/T Models). Disconnect electrical connections. Remove instrument panel hood, instrument cluster ezel and instrument cluster. Remove hood release handle. Remove knee protector. 3. Remove dash fuse/relay block and side trim. Remove engine control module box. Remove radio console and glove box lower reinforcement. Remove speaker covers and glove box. Remove heater control panel knobs and cover. Disconnect heater control cables, and remove heater control panel. Remove illumination control knob. Remove instrument panel. Installation 1. Install instrument panel. Install and adjust heater control cables. To complete installation, reverse removal procedure. Ensure mating marks on steering wheel and shaft align. Apply grease to contact ring and tighten steering wheel nut to 26 ft.lbs. (35 N.m).
