It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
What we need to do is try creating a new connection with your system.
1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon
2. Scroll over to the third page, and select "Internet."
3. Now choose "Connection Settings."
4. Click on "None" for "Connection 1."
(Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
5. Click on "Search for an Access Point."
6. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Look for your wireless network.
7.What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
You will now have 3 options
A. GOLD UNLOCKED LOCK (No security - Tap on your network name to save the settings and begin a connection test.)
B. GOLD LOCKED LOCK
WEP security - Your wireless network is secured with WEP and requires a security key.
Follow the steps now depending on your option
A. Select "OK," "Save Settings," and then "Yes."
The connection test was successful - Your Nintendo DSi is now connected online.
The connection test was not successful - If the test was not successful, you will receive an error code.
LET ME KNOW WHAT IT IS
B. WEP security - Your wireless network is secured with WEP and requires a security key.
Enter your WEP key
On the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
- Error Code 51300 or 51099: This means the security code entered into the Nintendo DSi is not the same one the router is set to. Scroll back up to step #3 of this page for the step-by-step directions. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
- All other error codes: Let me know what it is.
