Question about Vizio L32 32 in. LCD HDTV
Freezes When tv is on the picture freezes every few seconds and then comes back on and freezes again continuously
  • Lou Labetti
    Lou Labetti May 11, 2010
    How old is the set, or what is the model?
  • 104 Answers
You probally need a replacement mail board. Call vizeo and see if you have any warrenty or if you do not see if you can purchase a new main board.
Posted on Jul 29, 2008
2 Suggested Answers
40longyears
  • 287 Answers
SOURCE: picture freezes, sound continues for 5-10 seconds.
In these cases you might be able to see a picture by shining a bright light right next to the screen front. Do not put the light there for very long or you will end up with a permanent bright spot burt onto the screen. I have discovered that applying light pressure with a 3/8" thick rubber or plastic shim corrects a panel inverter/driver board/card solder problem with many flat panel TVs. (Removing the TV back is required, try light pressure against the inverter board while wearing rubber gloves and tv is then powered on.)
Posted on Oct 08, 2010
Bush BU102ZRH50 COMES ON FEW SECONDS PICTURE FREEZES
Corrupted firmware. A firmware update is necessary. Contact any service technician; or the authorized service center for Bush.
Feb 25, 2015 | Bush Televison & Video
When I first turn on my Technika tv I get sound but no picture. After hitting the top of the tv it comes on. After a further few minutes the picture freezes and eventually fades away. Further hitting of...
The dreaded loose connection syndrome, this could be easy or hard to trace, only solusion is checking circuit boards for bad connections , it may be also capacitors in power supply neading replaced, not a novice repair
pete
Nov 11, 2010 | Televison & Video
Picture on all 4 TV's in house randomly pixilate/freeze.
you have a low signal problem or if you have rj 59 in your home you need rg6 for at and t signal
Aug 27, 2009 | Vizio L37 Television
Picture freezes
this is a great factor with the weather EVEN CABLE TV IS THROUGH SATILLITE !!!! there could be bad weather 50 miles away and it will affect your signal..........
Jun 21, 2009 | Insignia Digital-to-Analog Converter for...
Frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Dec 09, 2008 | LG 37LC7D 37 in. LCD HDTV
TV keeps powering off and
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
Jun 03, 2017 | InFocus Televison & Video
Samsung HLR6167 - picture freezes
This is very common in Samsung DLPs. The DMD board is going bad. You will need to replace it.
Jan 07, 2008 | Samsung HL-R6167W 61" HDTV
Vizio L32 32 in. LCD HDTV Logo
265 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
