Question about Olympus FE-115 Digital Camera
I accidentally dropped my camera and now the lens won't go in! Also, nothing shows up on the screen :(
    Problem Solver:
  • 19 Answers
As an Olympus user, i have experienced the problem. A blank, or blue screen usually means that your computer has malfunctioned and possibly can no longer be used. To troubleshoot, try to remove and re-insert your battery and then power it back on. You can also try to recharge the battery and try this again.
Posted on Feb 28, 2011
SOURCE:
I damaged the lens of my dad's nikon coolpix S220, should i get it repaired or try something on my own
This is a specialist repair, I suggest you take it to a Nikon camers repairer.
May 10, 2013 | Cameras
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
Samsung Digimax S800 has lens stuck in open position. Replaced with fresh alkaline batteries, pressed on button, screen lit up for a second or so, turned off and gave 3 beeps. Any ideas? Thanks, Kevin
Did you accidentally drop it? If you did then there is a big chance that the lens is busted. If you didn't drop it, then it could be just dust/dirt inside the lens mechanism. Hold your camera with the lens facing the ground and then repeatedly tap it your camera gently - moderately to remove the dirt. You can also try spraying compressed air into it.
Sep 07, 2011 | Samsung Digimax S800 Digital Camera
.i accidentally dropped my nikon
The most recent estimate I received for replacing a lens mount on a Nikon lens was 55 USD. If you want to do the replacement yourself, you can order the part from
http://uscamera.com/jaa79351-f.htm
or
http://uscamera.com/jaa79851-b37.htm
depending on which 55-200mm lens you have.
Jul 28, 2011 | Cameras
My friend accidentally dropped my Sony Cyber-Shot DSC-HX5 on the hard ground. My camera still works and I do not have any error messages or physical damage on the outside. However, now my photos almost...
Apparently no physical damage but camera result shows internal damage of lens mechanism and lens assembly need to be replaced by local camera repair shop because camera will take apart for that and lens assembly can not be repaired, replacement is only option.
Let me know if there is additional question.
Thanks.
Apr 03, 2011 | Sony Cyber-Shot DSC-T5 Digital Camera
Black Screen on Canon PowerShot SD750
Probably bad CCD. !!! Check if there is possibility of free of charge repair !!! Many models are repaired free with CCD broken, even warranty time is passed.
Sep 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Casio EX-Z700 was dropped in sand. When camera is turned on lens makes a grating sound and the moniter screen is cloudy. It originally said lens error, but no longer says anything.
Hello, I'm Mark Faith from the states. I purchased the CASIO EX-Z700 series.
However, I accidentally dropped the camera when the camera was on and the lens was extended.
It makes a grating sound, and the monitor screen said "Lens error".
Now, the camera is turned off with its lens extended.
When I see the lens from the top, the lens position is more concentrated to the right, and the gaps between each lens is bigger on the left hand side of the lens.
I sincerely hope this would help you to analyze the lens situation.
I'll be patiently waiting for a list of solutions.
Thanks.
Mark
Aug 06, 2008 | Casio Cameras
Dropped my camera.
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jul 22, 2008 | Canon PowerShot A85 Digital Camera
Len
camera lens has problem.
need repair lens
mydc digital camera reapir
Jun 05, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
My optio was dropped with the lens going down first. now my camera makes noises & the screen is black. how do i go about fixing it?
looks like the gears or retracting mechanics are damaged.
its problably not worth to take it in, to get it fixed (depends on the camera). but most likely sound like the gears are busted.
you be paying for repairs that costing waaay more than the camera.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
May 20, 2008 | Kodak Easyshare M753 Digital Camera
Olympus FE-115 Digital Camera Logo
62 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
