Question about Coleman Mach 15 Air Conditioner
Coleman 15k will not come on
My coleman 15k with the hand held remote will not come on- the green light in the unit is on also i pushed the button on the ceiling panel and did not come on - worked ok 2 days ago - how do i ck this unit - pluged into 30 amp - and breaker ok
  • kerrycollins Aug 29, 2008
    System is getting power but will not respond to any thermostat controlls.
  • broken 1 Mar 26, 2009
    my coleman 15k with the hand held remote will not come on- the green light in the unit is on also. Ipushed the button on the ceiling panel and did not come on - worked ok yesterday- hooked to 50 amps.. checked all power connections. "brain box" will beep and click when the power is turned on or off. also, heater or fan settings will not work....
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
Here is the troubleshooting guide for your unit. Hope this helps.
TROUBLE SHOOTING GUIDE
TROUBLESHOOTING
Symptom Remedy
1. Remote does not turn on system
- Check and replace remote batteries if the display fades while
any button is activated or no display is present. - Point remote towards IR receiver during transmission. 2. System does not turn on, no green LED & no beep
- Check wiring. (see "installation instruction")
- Check modular cable to receiver.
- Check diagnostic LED status in the upper unit control box.
3. System does not turn on even when receiver green LED is on.
- Low or over voltage condition, check diagnostic LED status in the upper unit control box.
4. Fan runs but no cold air.
- Evaporator temperature sensor reaches low limit, defrost mode.
5. System runs continuously in the cool mode
- Remote was set for "I feel" mode and is left in a heated environment (sun etc.)
6. System runs continuously in the heat mode
- Remote was set for "I feel" mode and is left in a cool environment
1. Diagnostic LED (green)
(Note: Located on the control board in the upper unit control box.)
a) The LED is on when the 12VDC is adequate and communications are
present.
b) The LED is flashing fast and steady when in the freeze mode. Evaporator has frozen and the freeze proctection switch is engaged.
c) The LED is flashing slow and steady when the delay on break timer is
activated.
d) The LED is flashing 1 cycle on and off for one second with high or low
12VDC. Check the incoming 12VDC power for OK.
e) The LED is flashing 2 cycles on and off for one second with a
communication problem. Problem with the control board in the unit and the remote.
Hope this helps.
Jeff
Rate me Please!!!
Posted on Jul 04, 2009
Why won't my Genie garage door opener close without going back up.
So it seems the Main garage door unit on the ceiling is ok. The problem is with hand held unit. Usually the circuitry is ok. Try changing the battery. It has helped me. Also make sure the sensor on ceiling unit is not blocked ad is free of cobwebs.
Jun 26, 2013 | Genie Company Garage Door Parts Genie Gwkp...
How to reverse kichler ceiling fan, UC7206T
Stock Kichler ceiling fan c. 2006, works with replacement remote control 337001WH hand-held unit from Amazon 2013. Started running backwards when two remotes were activated at the same time by accident. Random button pushing on two remotes simultaneously got it to go back to forward. (Apparently original remote hand-held transmitter had forward/reverse setting, but the substitute 337001WH transmitter doesn't. When two transmitters run at the same time, the fwd/rev code may be decoded in the collisions at the receiver. Thank goodness!)
Jun 13, 2012 | Kichler Lighting 300105CTO Ceiling Fan
My fan was working with the remote then it stopped. I replaced the battery but the light doesn not light up when I push the button on the remote. Am I able to order a replacement remote without having to...
Before you rush out to by a new hand held remote, Check the battery to make sure it' s facing the right direction. Also, wipe off the receivers sensor, on the front of the AC unit, as dust and dirt can block it from receiving the infrared signal, If you do end up having to replace it, you can buy just the hand held remote transmitter, that's all you'll need to purchase. It will come with instructions on how to program to your existing receiver. You can probably get one from the manufacturer of your AC unit. Be sure to have the correct Model Number of your AC unit when you do.
Hope this helped you, Mary Alice. Please let me know. Thanks.
Jul 15, 2011 | Heating & Cooling
I have a hampton bay remote that just stopped working. I have installed new batteries, have checked the code with another remote so I know the problem isn't the fan. The light on the remote does not...
If the light on the remote is not lighting when you push a button, check the batteries to make sure they are in the proper position. If one is turned the wrong way, the hand held will not work. You may also want to check the replacement batteries to make sure they are fully charged. If all this fails to solve the problem, you will need replace the hand held remote. Since Hampton Bay Fans are a house brand for Home Depot, they stock and sell replacement hand held remote controls.
Hope this helped you. Please let me know. Thanks.
Jul 13, 2011 | Hampton Bay Heating & Cooling
The hand held remote no longer activates the ceiling fan or the light. I know I have power to the unit and know that the battery in the remote is ok. When I press the remote for the fan or lite the red...
If you only change the battery in the hand-held remote, there should be another one in the fan housing that also needs changing. Always change all the batteries at the same time.
Apr 04, 2011 | Hampton Bay Heating & Cooling
Our garage door is not opening with the wall unit or remotes. When I push the wall unit I hear a click from the ceiling unit. The door operates fine manually. The green light on the ceiling unit (the SRT...
The green light on the motor unit is an LED and random flickering is normal. Your problem is most likely caused by an electrical storm or power surge. You will need to remove the logic board from the motor unit and check for burnt or missing traces on the printed circuit board especially around the small transformer. Your holding that button in will most likely have erased the memory of the unit and all your remotes will need to be programmed once you find your problem. I really suggest you call an technician at this point.
Oct 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have 2 Remote Control Model UC7848T units. Unit #1 Lowest speed doesn't work at all, middle speed and high speed still working. Light control work fine. Unit #2 Great difficulty in turning on or...
You need to completely disassemble the hand held remote unit, remove the rubber push buttons and clean the contacts. Mine do this frequently. The contacts are black and will be slimey. I just use soapy water and a soft cloth to gently clean them. Be sure to dry them completely before reassembling. Also be sure you dont get any of the electronics wet.
Sep 15, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a chamberlain garage door opener. It came with an appliance control remote control. How do I set it up? when I plug my light into it, I can push the button and turn on the light but the remote...
Plug the appliance control into a 120 Volt outlet.
Press and release the "learn" button on the appliance control. The learn indicator light will glow for 30 seconds.
Within 30 seconds press and hold the button on the hand-held remote.
Release the remote control push button. Code setting is now complete.
Aug 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote is not working
The most likely cause is a problem with the hand held remote. These units use infrared light which the eye can not see. But if you have a digital camera it can! Look at the remote through the view screen of the camera while someone pushes buttons pointing at you. If it is working you'll see a pulsing light. if not change the batteries or try a universal remote.
May 08, 2010 | Avermedia AVerDiGi EB1304 Net
Coleman Mach 15 Air Conditioner Logo
491 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
