Dear i_mckie224,
Most toilets you will find that the cistern lid should lift off without the need to remove any screws, nuts or bolts. some on the otherhand, such as the Dudley Elite, sometimes has a screw on the top of the cistern that you need to turn in order to remove the lid, but generically, as said, they should either lift or slide off. If you can provide me with more details about the toilet itself, then I will be able to assist you in finding the answer
Yours sincerely
Oz
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to left out the second button, then release the first button and pry that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
