Question about GE Energy Star WCVH6260F Front Load Washer
Wet cloth washer does not spin out clothes
  • roddie1961 Jan 02, 2009
    i have a ge front load washer that will not go into high speed spin
    cycle . i have located the drain filter and cleaned out same.unit drains properly but will not spin on high speed and clothing are still
    soaking.can you suggest any solution.
  • Anonymous Jan 05, 2009
    Will not spin high speed
I had the same problem so I called a tech he came out ran all the test and nothing happened. So he cleaned out the trap it had some nasty stuff but once it was cleaned out it worked just fine. He told me to do this every 2-3 months.
Posted on Jul 30, 2008
Clothes still wet after spin
it is normal for clothes to be a bit wet after spin.approximately about 80 percent of your clothes will be dry after spin. you may hang your clothes to completely dry or place it inside a drier machine
Sep 03, 2015 | Maytag Bravos 3.8 Cu. Ft. Washer
MY WASHER SPINS AND DRAINS THE WATER BUT MY CLOTHES ARE STILL WET
are you sure that its spinning as this is a common problem with wet clothes. When the cycle is complete the clothes should be wrapped around the bottom of tub not just lying there,
Sep 26, 2011 | Admiral AW22 Top Load Washer
My washer spins out very slowly and the water drains but the clothes are very wet.
f the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing.
Nov 30, 2010 | Westinghouse WWS833ES Super Capacity Top...
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
The washer won't spin dry. It fills and empties but the clothes are soaking wet.
If washer is spinning but clothes are wet suspect a partial blockage in the outlet pipe. This will cause the water to drain to slow and leave some in the outer drum while spin occurs but this ends up back in the clothes.
Feb 25, 2010 | Washing Machines
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front load washer will not spin. Clothes come out wet.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Mar 02, 2009 | Kenmore 43142 Front Load Washer
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
GE Energy Star WCVH6260F Front Load Washer Logo
81 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
